Thread: Battery coding
  1. Battery coding
    Jun 2009
    Bromley, Kent
    Hi all I just fitted new battery to my A4 B8. I put a Bosch S5 battery but the messages on the screen about low battery is still coming up. After hours of trying to find solution I understood that I need to do coding on the battery. Does any one know how to do that using VCDS?
    Any help is much appreciated
  2. Re: Battery coding
    Oct 2010
    Cirencester, Gloucs
    Google audi b8 Ross tech battery coding. On the Ross tech site they have a step by step guide and screen shots mate
    Audi A4 B8 S Line - VCDS - needle sweep - LED number plate lights - painted calipers with S Line decals - Audi Drive Select - Cruise Control - OEM S4 pedals & RS5 footrest - facelift flat bottom steering wheel - LED interior lighting pack - rear view camera/xcarlink - carbon fibre wrap interior trim - OEM S4 power fold wing mirrors - OEM rear sunblinds - OEM LED tail lights- RS4 style grill
  3. Re: Battery coding
    Jun 2009
    Bromley, Kent
    Thanks I have already looked them and I will try to do it tomorrow but it is a shame I did not write down the serial numbers from the new battery and it is a pain to get to the battery. Do I need to enter the same numbers as they are on the battery or I can just change few figures?
  4. Re: Battery coding
    Oct 2010
    Cirencester, Gloucs
    Enter the numbers (10 figures) as they are on the battery after you input the manufacturer code. This enables your system to learn the new battery that way you won't get the low battery warning all the time
  5. Re: Battery coding
    Mar 2011
    Clitheroe, England
    11 Post(s)
    Before you do that....... I had the same thing at the end of last week - new battery fitted & DIS still said 'low battery level'. I almost went through the rigmarole of getting it coded etc. The problem seems to have cured itself however after I just took the car for a decent run out. My Dad had the same thing with his old Volvo too when the AA fitted a new battery & he said the car just needs to be run to let the car 'get used to the new battery' or something. Have you tried driving it for 20 mins since fitting the new battery?
    The Only Way Is A6!
  6. Re: Battery coding
    Oct 2010
    Cirencester, Gloucs
    I think it will learn your battery on its own if you don't let the old battery charge drop too low. I can't remember what the percentage is but if it does drop too low it goes into a safe mode and the new battery will need to be coded
  1. New battery, is coding required?
    By gregpot2000 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-01-2014, 11:02 PM
  2. Battery Monitor Coding Question
    By apole in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-09-2012, 04:45 PM
  3. Shorted battery by accident now car won't start - battery is good...
    By Nookster in forum Golf MK4 - 1999 - 2004
    Last Post: 19-12-2011, 06:32 PM
  4. A6 2006 BAttery Coding
    By snight123 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-04-2011, 10:10 AM
  5. BATTERY LIGHT ON 2.7TDi Q 2005 - NO BATTERY CHARGE
    By shairaz1 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-07-2009, 02:05 AM
