Thread: How to read OBD-II diagnostics on 1999 TDi
Results 1 to 9 of 9
  1. How to read OBD-II diagnostics on 1999 TDi
    Dec 2013
    United Kingdom
    Hi, I'm trying to read the diagnostics on my 1999 1.9 TDi AFN Passat.
    I bought a "Mini V1.5 ELM327 OBD2 Bluetooth Interface" from Timetop via Amazon & have tried to use it with various Android apps (the free versions of Torque, OBD Car Doctor & OBDAutoDoctor). They seem to connect but don't read any data.
    Can anyone point me at a cheap way of doing this please? I don't want to spend loads because depending on what it finds, I may have to take it to a garage for repairs anyway.
  2. Re: How to read OBD-II diagnostics on 1999 TDi
    Aug 2011
    Meath
  3. Re: How to read OBD-II diagnostics on 1999 TDi
    Dec 2013
    United Kingdom
    Quote Originally Posted by Doctle Odd View Post
    Thanks for your suggestion, Doctle Odd. If my laptop had a battery which worked, I'd be happy with that but before I take that route, are there any alternatives? I suppose a Bluetooth module is too much to expect but how about one of those standalone readers (I've seen a U280 device in tasteful industrial orange)?
  4. Re: How to read OBD-II diagnostics on 1999 TDi
    Aug 2011
    Meath
  5. Re: How to read OBD-II diagnostics on 1999 TDi
    Dec 2013
    United Kingdom
    I've just ordered one. I'll offer the ELM to my friend to see if it can talk to his Peugeot.
  6. Re: How to read OBD-II diagnostics on 1999 TDi
    Aug 2011
    Meath
    I had an ELM cable years ago it was like my cat in that it spoke to nobody or nothing
  7. Re: How to read OBD-II diagnostics on 1999 TDi
    Dec 2013
    United Kingdom
    I'd just like to confirm that the VS450 works fine and has listed quite a few error codes. Now all I have to do is fix them.
    2 1 0
  8. Re: How to read OBD-II diagnostics on 1999 TDi
    May 2014
    England, M4
    did you try erasing the codes ? then driving a little (safely of course, i don't know what problems you have) then re-scanning to compare before and after results ?
    A4 AFN 170k 1.9tdi 110bhp MY1998
  9. Re: How to read OBD-II diagnostics on 1999 TDi
    Dec 2013
    United Kingdom
    Quote Originally Posted by Drive View Post
    Sorry for keeping you waiting; there was someone at the door.
    Well I left the car for a long time & the battery went flat. After charging it I found that all the error codes had gone. Once I started driving, only one of the errors (the main one I'd been concerned about) returned: the front r/h ABS sensor was s/c or o/c. Upon investigating I found that 2 or 3 of the clips which held the sensor cable to the wheel arch had failed (after only 15 years), allowing the cable to be worn through by the front wheel. Soldering iron, heat-shrink sleeving & cable ties fixed it again. The clips had failed on the l/h front wheel too but the cable hadn't worn through. So all in all, a good result.
    0 2 0
  1. A6 2008 2.0 tdi diagnostics check.
    By 1966baz in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-04-2013, 08:19 PM
  2. Sharan 2.8 VR6 aut. , 1999, OBD??
    By Sharan99 in forum Touran - Sharan - Caravelle
    Last Post: 10-11-2012, 10:34 PM
  3. 2006 3.0 TDi does not turnover when key is turned, OBD P1625, P3325, P161A-F... HELP!
    By jonnieboyracer in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 09-04-2012, 02:05 PM
  4. Question Where is the diagnostics port on 2005 tdi Touran?
    By Buzzoff in forum Touran - Sharan - Caravelle
    Last Post: 03-05-2011, 01:47 PM
  5. Question I need to replace my cats on my 2.4, how do I tell if I need OBD or non-OBD?
    By Carpie in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-01-2011, 09:39 PM
