Thread: A4 2010 memory seat issue
Results 1 to 10 of 18
  1. A4 2010 memory seat issue
    Nov 2013
    Hi everyone,
    This is my first post on this forum so be gentle!!
    Purchased a 3.0tdi yesterday with memory seats. I can select the on/off button on the door and the light works. When I press the set button, the light does not illuminate. Pressing 1 or 2 does move the seats and mirrors so it must have been set at some point.
    Any help appreciated.
    Thanks.
    A4 3.0TDI Quattro S-line Special Edition S Tronic, Phantom Black, black leather, memory and heated seats, memory mirrors, 19" rotor alloys, MMI Navigation Plus, Bluetooth, rear electric blind and manual side blinds, AMI, CD changer, B&O system, DAB radio, advanced key (keyless entry and start/stop), Hold Assist, Parking System Plus, voice recognition.
  2. Re: A4 2010 memory seat issue
    46 Post(s)
    Welcome to VWAF
    Have you checked the user manual? Could be a step you're missing.
    Post some pics
  3. Re: A4 2010 memory seat issue
    Nov 2013
    Welcome to VWAFHave you checked the user manual? Could be a step you're missing. Post some pics
    Thanks!Yes checked manual and steps. Even checked a YouTube video to confirm.Will get pics up ASAP Cheers
  4. Re: A4 2010 memory seat issue
    Nov 2008
    Hants
    Welcome! Nice to see another 3.0TDI Special Edition.
    The profiles can also be stored for each key which is normally easier. So that as you unlock the car it moves to the correct position.
    Procedure is:
    - go to CAR menu in MMI and select Seat Adjustment, Drivers Seat, Remote control key -> ON
    You can also store a profile in the 1 and 2 buttons:
    - set seat to position you want
    - press SET and wait for it to light up
    - press 1 or 2, should hear a beep
    The pressing 1 or 2 will make the seat move to the stored position.
    Pressing OFF stops the seat recall function working.
    Dave
    2014 Audi A3 Sportback 2.0 TDi S Line Quattro S tronic
    2010 Audi A4 3.0 TDi S Line Special Edition Quattro Avant S tronic (previous)
  5. Re: A4 2010 memory seat issue
    Nov 2013
    Quote Originally Posted by dts439 View Post
    Welcome! Nice to see another 3.0TDI Special Edition.The profiles can also be stored for each key which is normally easier. So that as you unlock the car it moves to the correct position.Procedure is:- go to CAR menu in MMI and select Seat Adjustment, Drivers Seat, Remote control key -> ONYou can also store a profile in the 1 and 2 buttons:- set seat to position you want- press SET and wait for it to light up- press 1 or 2, should hear a beepThe pressing 1 or 2 will make the seat move to the stored position.Pressing OFF stops the seat recall function working.
    Hi Dave,Thanks for the detailed steps. I have already tried that but the issue is with the Set button not illuminating. I think there may be a fault.
  6. Re: A4 2010 memory seat issue
    Jul 2008
    I had a similar problem on mine last year. Followed instructions to the letter but Set would not work. Had a local guy do a fault scan and found there was an intermittent low voltage to the door control module. He cleared the fault code and memory seats have been working fine now for over a year. So I would get a fault scan done. There are guys on the forum that may be near you who can do this.
  7. Re: A4 2010 memory seat issue
    Nov 2013
    Quote Originally Posted by mhurer View Post
    Thanks for the help. Anyone in the Watford/Harrow area?
  8. Re: A4 2010 memory seat issue
    46 Post(s)
    Quote Originally Posted by Kevin_m View Post
    Have a look here VWAF User Location Map - VCDS - Google Maps
  9. Re: A4 2010 memory seat issue
    Nov 2013
    Thanks again Chris. Thats a great idea with the map. User Fla lives not far but I do not have enough posts to DM him!! If anyone can DM him and ask him to DM me that would really help.
  10. Re: A4 2010 memory seat issue
    46 Post(s)
    Will do now
  1. A4 Memory Seat questions
    By wmccann in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-02-2011, 12:44 AM
  2. Q7 Seat memory codes
    By Spud312r in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 09-04-2010, 06:43 AM
  3. Retro fitting seat memory
    By 20vcqdriver in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 24-03-2010, 09:59 AM
  4. Please Help Memory Seat longitudinal motor issue
    Last Post: 06-08-2009, 12:23 AM
  5. Memory Issue On Headunit
    By kasper1287 in forum Golf MK4 - 1999 - 2004
    Last Post: 13-09-2007, 10:24 PM
