Thread: Steering Column Lock -- which CCM needs changing?
Results 1 to 10 of 10
  1. Question Steering Column Lock -- which CCM needs changing?
    Sep 2008
    SE London
    Equired at main dealer about which revisions of CCM need to be replaced if the Steering Column Lock fault shows itself as mine being an '06MY am unsure whether to carry this risk any further.
    Got told that early CCMs do need changing too but later ones don't. Does anyone know which are "early" and which are "later"? Brings fixing fault cost to nearly a grand at dealer as against £300-ish for board swap and re-code immo alone.
    I've got:
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3C0 959 433 K HW: 3C0 959 433 K
    Component: IMMO 038 0367
    Revision: 00038000 Serial number: VWZCZ000000000
    Shop #: WSC 131071 1023 2097151
    VCID: 3245D739AD93D88E48D
    Subsystem 1 - Part No: 3C0 905 861 D
    Component: ELV 024 0370
    3C0905861D ELV 024 0370
    No fault code found.
  2. Re: Steering Column Lock -- which CCM needs changing?
    DSG4ME Guest
    Sell it
  3. Re: Steering Column Lock -- which CCM needs changing?
    Sep 2008
    SE London
    Quote Originally Posted by DSG4ME View Post
    Sell it
    Already turned down six big ones for it (SEL, all done, fully loaded) Coz what else can I get with this spec for this price with only 62k miles up?
    Mind you, there's some good Jag XF's around. 'Cept they're all Silver with beige interior. And not my time yet for a Pringles jumper...
  4. Re: Steering Column Lock -- which CCM needs changing?
    Norfolk
    Quote Originally Posted by RichardSEL View Post
    I've got:
    I don't understand your question. The ccm was never the problem. The problem was coding the nwe lock. The new 'new' lock can now be coded to the original ccm so ccm doesn't need changing.
  5. Re: Steering Column Lock -- which CCM needs changing?
    Apr 2007
    France
    12 Post(s)
    Another 'Eye' reader?
    1996 Laguna 2.2D
    1977 MGB roadster
  6. Re: Steering Column Lock -- which CCM needs changing?
    Aug 2011
    Meath
    Pringles jumper and Rupert the bear trousers
  7. Re: Steering Column Lock -- which CCM needs changing?
    Sep 2008
    SE London
    Quote Originally Posted by martin1810 View Post
    Thanks for that Martin, and I figured you would've made mention on your website entry if this was so. Mine hasn't gone faulty, but dunno whether I want to carry the risk of a near £1k bill on a car only worth £6k at most. But if you see this thread:
    UKpassats.co.uk • View topic - Steering Lock and Convenience Module
    you'll see that there's two posters there that have had this experience of being told by main dealer at the point of doing the works of the extra £600 or so of expense due to CCM.
    Both US and RoW TPi covering this doesn't mention what CCM revisions are affected.
    (later) And another in this thread:
    VWVortex.com - Old issue in US. I'm after advice on electronic steering lock/ccm replacement in UK
  8. Re: Steering Column Lock -- which CCM needs changing?
    Norfolk
    Many dealers don't know what they are talking about because they confuse old situation (change ccm and steering lock) with new situation (change lock and reprogram). On rare occasions the steering controller needs changing with the lock because it has gone faulty at the same time. ccm should not need changing. Steering lock costs £75. You can disconnect old one and leave it hanging. Drive to dealers. Swap to new one and pay for the coding. OR let them do whole job for about £350. Removing lock is a pain. It's easy to do but fiddly to get the column out.
  9. Re: Steering Column Lock -- which CCM needs changing?
    Sep 2008
    SE London
    Quote Originally Posted by Quatrelle View Post
    Yes Took a copy into work for one night shift.
    Was accused of bringing seditious literature into the workplace
  10. Re: Steering Column Lock -- which CCM needs changing?
    Apr 2007
    France
    12 Post(s)
    You have a PM.
    1996 Laguna 2.2D
    1977 MGB roadster
  1. Steering Lock column Defective !!!
    By PDL in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-05-2015, 08:25 AM
  2. Steering Column Lock
    By jimgironde in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-10-2013, 10:05 AM
  3. Attention steering lock/ column problems
    By corro in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-04-2011, 11:19 PM
  4. Please Help Steering column lock defective!
    By the surfer in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-02-2010, 12:45 PM
  5. Question Steering Lock column Defective
    By tobetrue123 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-12-2009, 07:18 PM
