Hello everyone
, thanks in advance for any advice given and time taken on your behalf.
I unfortunately had a bad experience with a car dealer who sold me on his word that everything faulty would be addressed and then fobbed me off, so I have rectified almost all of these issues at my own further expense, but have just finally bit the bullet with the most pressing issue. This was with my ABS Module failing which is apparently a common fault on the A4. I sent this off to BBA Re-man who informed me that it was beyond repair, and sold me a replacement for £476
. As my original unit was knackered it wasn't possible to read the codes from it so I have to start from scratch.
I fitted the re-conditioned ABS Module (complete) without issue but am now struggling to re-code the module to my car. I have a friends VCDS/VAG-Com so should be ready to go. My problem is that even following Ross Tech instructions to obtain my login code and softcode the VCDS will not allow me to login to my ABS to re-code it
, so I guess I am entering the wrong numbers? The VCDS works perfectly with it's owners Seat Leon Cupra R and again with my Wife's Golf 1.8T, so I doubt issues there.
I have a 2003 A4 3.0 Quattro Petrol Manual.
According to Ross Tech my:
Login should be 09395
Softcode should be 04495
I have also tried two indi garages who do not have the correct equipment to code the ABS which has led me to borrowing, although my friend is a little precious with his lead, so I'd like to return it as soon as possible (along with his netbook).
I would be very grateful indeed if someone could point me in the right direction to obtain the correct codes so I can get my car back on the road (with winter wheels and tyres!) before the tyres rot and don't get to enjoy the snow!
