Just an update on threads relevent to the failure of cam follower on the titled engines.
Don't Let This Happen to You
Here's some of the threads seen in various forums & further info available --
Updated with URLs as seen
VW US/Canada has increased warranty on this to 120k mile. They check the cam lobe too and if this has been scored change out. The timing chain tensioner can be affected due to increased load.
Check your Cam Follower People
VWVortex.com - This can happen to you, Check your Cam Follower
Failed Cam Follower Experience
http://forums.vwvortex.com/showthrea...ues&p=82127526
VWVortex.com - Soooo I checked my cam follower yesterday...
UKpassats.co.uk • View topic - Cam follower and the annoying banjo bolt
2008 FSI "Uh-Oh": Fuel Pump Cam Follower / Intake Camshaft
Broken HPFP return spring:
UKpassats.co.uk • View topic - This could happen to you
Incomplete video for changing at: http://www.vimeo.com/moogaloop.swf?clip_id=23010188
Good install change file:
http://bd8ba3c866c8cbc330ab-7b26c6f3...er_Install.pdf
Broken HPFP pump contact insulator:
VWVortex.com - Checked Cam Follower and Noticed Cracked Part
Thicker replacement cam follower CDN $108.90, US $99 +shipping:
KMD Tuning - 2.0T FSI Cam Follower with Armoloy - PG Performance
