Thread: Question regarding the acoustic sound from the rear parking sensors
Results 1 to 9 of 9
  1. Question regarding the acoustic sound from the rear parking sensors
    Nov 2013
    Malta
    I am buying an Audi A3 Sport, 2nd hand. It comes with factory fitted rear parking sensors, which work perfectly however the acoustic sound is very low. Is there a way I can increase the volume?
    Would really appreciate your help on this one.
    Thanks,
    Pietru
  2. Re: Question regarding the acoustic sound from the rear parking sensors
    46 Post(s)
    You should be able to adjust the volume via the DIS using the reset and rocker switch on the end of the wiper stalk.
  3. Re: Question regarding the acoustic sound from the rear parking sensors
    Jan 2012
    Coding Something
    Depends on the year & modules versions installed, not all systems were enabled or possible for comfort menu's on the dis.
  4. Re: Question regarding the acoustic sound from the rear parking sensors
    Nov 2013
    Malta
    I managed but the acoustic signal is still quite low and music does not stop when reverse is activated!
  5. Re: Question regarding the acoustic sound from the rear parking sensors
    Jan 2012
    Coding Something
    Only newer modules engaged a canbus signal to the head unit to lower the music volume, which IMHO isn't low enough.
    You can change volume on any year oem sensor system via vcds, but as stated not all have dis facilities for this.
  6. Re: Question regarding the acoustic sound from the rear parking sensors
    Nov 2013
    Malta
    Mine is a 2012 model, which is quite recent. What do you think?
  7. Re: Question regarding the acoustic sound from the rear parking sensors
    Jan 2012
    Coding Something
    Need to know the module part number to see the age, are they factory fitted/retrofitted oem system?
  8. Re: Question regarding the acoustic sound from the rear parking sensors
    Nov 2013
    Malta
    Yep exactly
  9. Re: Question regarding the acoustic sound from the rear parking sensors
    Nov 2013
    Malta
    Factory fitted
  1. Parking Sensors/Visual Display Question
    By Kaiser2000 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 23-07-2013, 07:14 PM
  2. Hit 51 mpg today! (plus question r.e. parking sensors)
    By 08a6 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-09-2012, 01:13 PM
  3. Rear Parking Sensors
    By clio222 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-11-2011, 10:18 PM
  4. beeping sound (higher pitch than parking sensors) problem
    By denkatenka in forum A8 - S8 - V8
    Last Post: 19-02-2010, 08:47 AM
  5. Rear Parking Sensors
    By Jasperse in forum Jetta MK3 - 2005 - 2013
    Last Post: 26-08-2008, 04:41 PM
