Thread: Has anyone done a guide to changing oil and filter on a 2.0Tfsi?
  1. Has anyone done a guide to changing oil and filter on a 2.0Tfsi?
    Feb 2012
    Christchurch Dorset
    I've used the forum search but haven't been able to find what I'm looking for and Google searches have confused me even further.
    So far I've been told that I need a special drain tube for the plastic oil filter housing (and then been told that I don't) and also that I need a special cup socket to remove the housing.
    Ideally I'd like to read a 'step-by-step walkthough' on how to do the job. Has anyone produced one or have plans to do so?
    Audi newbie
    58 A4 2.0 Tfsi S-line SE Cabriolet in Misano red with retrofitted Westfalia removable tow bar and cruise control
  2. Re: Has anyone done a guide to changing oil and filter on a 2.0Tfsi?
    Aug 2009
    Near Lanark
    21 Post(s)
    Can't really help other than to say I was chatting to my indy recently.
    He said the oil filter is tricky to change and is quite awkward to get at, even with the car up on a ramp.
    Reason I was talking to him is because I thought my car had a leak....I kept leaving rainbows in the wet. Took it back to him after he had serviced it and he checked it all out and explained to me that the filter is above a cross member and sometimes, because it's awkward, some oil can get inside the cross member then over a period of time drip back out giving the impression of a leak.
    He was more than happy to clean all the underside and said if I had any suspicions to go straight back to him.
    Your advice about a special tool may be true based on the trickiness of removing the filter, but I'm not sure.
    A6 C7 Saloon 3.0Tdi Quattro S Line | 242bhp | Quartz Grey
    2016 Triumph Street Triple | 106bhp | Pearl White
    VCDS owner - Lanarkshire Area. PM Me if you need help.
  3. Re: Has anyone done a guide to changing oil and filter on a 2.0Tfsi?
    Feb 2012
    Christchurch Dorset
    Thanks for that. I should have added that I've been told that the filter canister is removed from the top of the engine and also that it comes out from underneath!
    I've booked it into my local independent VAG specialist this time but it hurts having to pay for their labour if it is a relatively straightforward job that I could do myself.
    Audi newbie
  4. Re: Has anyone done a guide to changing oil and filter on a 2.0Tfsi?
    Aug 2011
    Meath
  1. Please Help A5 2.0TFSI Oil consumption unbelievble!
    By glammr in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 22-07-2019, 06:43 PM
  2. A Beginners Guide to Changing the Cam-Belts on 2002 Audi Allroad 2.5 TDI Automatic AKE
    By ceilidhalfie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-02-2016, 10:53 PM
  3. Question 2.0tfsi oil capacity
    By m3gt2 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-02-2011, 08:38 PM
  4. 2.0TFSI with Oil pressure problem on track
    By grr in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-08-2010, 12:42 PM
  5. Filter changing
    By shropslad in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-06-2010, 09:38 PM
