Thread: Audi A6 Allroad compressor location
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 46
  1. Re: Audi A6 Allroad compressor location
    #31
    Ayrshire, Scotland
    18 Post(s)
    2 issues, the error “open or short to ground” is still that plug, the g291 sensor is in the valve block, it’s not faulty but the connection to it is,
    the rear sinking, very common on the C6, try this;
    park in allroad (lift) setting overnight to see if the car drops from this setting, then next night park in dynamic setting, if it always sinks parked in dynamic, but doesn’t sink in the higher settings it’s the airbag leaking.
    report back
    best regards
    andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  2. Re: Audi A6 Allroad compressor location
    #32
    Sep 2018
    Edinburgh
    Ok thanks Andy, I'll have to have another go at the connector another day. As I've manged to break the plastic clips I may have to solder a new one on. ��*♂️
    OK will try the experiment on the dropping tonight and report back.
    Many thanks,
    Chris
  3. Re: Audi A6 Allroad compressor location
    #33
    Sep 2018
    Edinburgh
    Hi Andy,
    Right, I cleared the fault codes which brought the menu back up, and I selected 'comfort'. It inflated itself up to there without any issues.
    Then I went to put the car into 'allroad' and it got pretty high and then it failed and let itself down to comfort sort of height again, greying out the menu. So I left it overnight and the back had gone back down to the bump stops again.
    This morning clearing the errors and selecting comfort riases itself up OK, and the car drove fine. The error message that endures after the clearing is still the same one, but perhaps this is the dodgy connector rather than anything to do with the leak. I have ordered a new connector body by the way so I'll fit that in due course to make sure it clips nicely in again.
    Address 34: Level Control Labels: 4F0-910-553.clb
    Part No SW: 4F0 910 553 A HW: 4F0 907 553 A
    Component: J197 LUFTFEDER H17 0060
    Serial number: 00619000147200
    Coding: 0000210
    Shop #: WSC 00557 210 58459
    VCID: 221D1705B8C88C77FF1-8076
    1 Fault Found:
    01772 - Signal from Level Control Pressure Sensor (G291)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 227
    Mileage: 300236 km
    Time Indication: 0
    Date: 2020.03.31
    Time: 07:18:07
    Does the above give you any more clues or should I get the soapy water out and look for bubbles? :-)
    Many thanks!!
    Chris
  4. Re: Audi A6 Allroad compressor location
    #34
    Ayrshire, Scotland
    18 Post(s)
    Ok, so in dynamic it sinks, park it at its highest setting, to do this, clear the error, take it for a 10 min drive, this will top up the storage tank then ask it to lift up once up at the highest it will go enable jack mode on, then leave it to see if it sinks
    The fault code and sinking are not linked, the fault code is that connector or wires to it.
    The sinking is likely the airbag, try it at as high as it will go left overnight and report back
    best regards
    andy
  5. Re: Audi A6 Allroad compressor location
    #35
    Sep 2018
    Edinburgh
    Okey doke, many thanks I'll try that tonight.
    Cheers,
    Chris
  6. Re: Audi A6 Allroad compressor location
    #36
    Sep 2018
    Edinburgh
    Hi Andy,
    OK so I've tried a couple of times to get it to go to its highest setting after a decent drive and it wont quite get there - in comfort setting whilst driving along it d=goes up 1 setting, but then when you slow down and it tries to go up the next level it times out and sinks back down to level 2.
    When I put it in jack mode last night it had sunk down again on both sides at the back, but of course thats basicaly at dynamic level again. However if if keep an eye on it on the way down it looks like the rear drivers side sinks first and looks lower than the others.
    The new connector shell has arrived so when I do that I'll make sure I have re-connected the brown compressor pipe into the block nice and tight. Otherwise should I do the soapy water test on the rear drivers side bag?
    Many thanks,
    Chris
  7. Re: Audi A6 Allroad compressor location
    #37
    Sep 2018
    Edinburgh
    Hi Andy,
    After a few attempts I managed to park it at the higher setting and left it in jacking mode and it didn't drop. Is this useful?
    Many thanks,
    Chris
  8. Re: Audi A6 Allroad compressor location
    #38
    Ayrshire, Scotland
    18 Post(s)
    Yes, it’s definitely an airbag leak, if it doesn’t sink on high setting but always sinks on lowest setting it’s the airbag,
    now park in dynamic setting, enable jack mode and what ever corner sinks the lowest has the leak, replacement airbag around £50-60 online,
    the car struggling to lift suggests the compressor not strong enough, what condition was the cylinder when you fitted the piston ring? Any scoring or deep marks
    best regards
    andy
  9. Re: Audi A6 Allroad compressor location
    #39
    Sep 2018
    Edinburgh
    Thanks Andy, will do.
    The compressor felt OK, both the old piston ring and the bore felt smooth. I'll double check that when I re-fitted the brown pipe into the block that it isn't letting by.
    I'll see which airbag drops and I'll order one. I think it's the drivers side rear as that always seems to drop first.
    Thanks again.
    Chris
  10. Re: Audi A6 Allroad compressor location
    #40
    Nov 2022
    Sweden
    Sorry to yet again bump this old thread.
    I have en A6 Allroad -07 that has en intermittent fault.
    I have changed the compressor, the fuse and the relay.
    The yellow light start flashing almost every time I drive it. And the MMI gets all grey. I clear the codes and sometimes I can drive for 2-3h before it comes back. It always goes down to Comfort and stays there.
    I only have a cheap reader and it shows - 02645 - Solenoids for lever control system.
    I know I broke some of the pins to some connectors when I changed the compressor. But I used what we in Sweden call "Cat stranglers" and you guys call zipties to tighten the connectors. Could that be the problem ?
    Best regards !
    Jonatan from northern Sweden
  1. Allroad air compressor vs. A6 rear self leveing compressor
    By g.suggy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-06-2012, 11:00 AM
  2. Replacing Air Con Compressor on 2002 Audi Allroad 2.5TDI AE
    By ceilidhalfie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-03-2012, 06:44 PM
  3. Please Help Audi Allroad door switch location ?
    By ivano24 in forum Chat - Completely Off Topic
    Last Post: 04-07-2009, 10:23 PM
  4. Noisy air compressor, Audi Allroad
    By safesurfer65 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 22-04-2008, 09:29 AM
  5. Audi Allroad (...to 2005) - Air Compressor
    By Cooperman in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-03-2008, 08:31 PM
