Thread: Audi A6 Allroad compressor location
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 46
  1. Re: Audi A6 Allroad compressor location
    #21
    Ayrshire, Scotland
    18 Post(s)
    Yes all 3 plugs need to be connected so the error light flash,
    in vcds show a photo of the fault codes for module 34 - level control
    also go to measuring blocks and show a photo of group 004
    and we can go from there
    regards
    andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  2. Re: Audi A6 Allroad compressor location
    #22
    Sep 2018
    Edinburgh
    Hi Andy,
    Sheenshots attached.
    I reattached the compressor but I couldnt hear it running at all. It could have come on very quickly and I might have missed it but I dont think so.
    Any thoughts gratefully received.
    Many thanks,
    Chris
  3. Re: Audi A6 Allroad compressor location
    #23
    Sep 2018
    Edinburgh
    I dont think you could see those....
    text dump as follows
    Tuesday,24,March,2020,19:07:56:30678
    VCDS Version: 19.6.2.2 (x64) HEX-V2 CB: 0.4508.4
    Data version: 20200210 DS308.0
    Ross-Tech: Home
    Address 34: Level Control Labels: 4F0-910-553.clb
    Control Module Part Number: 4F0 910 553 A HW: 4F0 907 553 A
    Component and/or Version: J197 LUFTFEDER H17 0060
    Software Coding: 0000210
    Work Shop Code: WSC 00557 210 58459
    VCID: 221D1705B8C88C77FF1-8076
    3 Faults Found:
    01772 - Signal from Level Control Pressure Sensor (G291)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 117
    Mileage: 291793 km
    Time Indication: 0
    Date: 2019.05.18
    Time: 18:53:23
    02645 - Valves for Level Control System
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 224
    Time Indication: 0
    01399 - Relay for Level-Control Compressor (J403)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 12
    Time Indication: 0
  4. Re: Audi A6 Allroad compressor location
    #24
    Sep 2018
    Edinburgh
  5. Re: Audi A6 Allroad compressor location
    #25
    Ayrshire, Scotland
    18 Post(s)
    Ok, if you clear all those codes and the 2 open or short to ground errors come back, check the 10 pin connector on the valve block, it suggests it is unplugged, go check it unplug it, clean, inspect wires in this plug for damage and corrosion then refit and test car again
    these codes are stopping the system working, everything else looks ok
    report back once the 10 pin plug has been checked
    regards
    Andy
  6. Re: Audi A6 Allroad compressor location
    #26
    Sep 2018
    Edinburgh
    Thanks Andy, I'll try in the daylight tomorrow and let you know. Fingers crossed.....!
  7. Re: Audi A6 Allroad compressor location
    #27
    Sep 2018
    Edinburgh
    Hi Andy,
    I tried disconnecting the plug, cleaning both sides and putting it back together but no change. It was a little tired looking on some of the contacts but fairly clean and not corroded to the extent that you would think it was an issue.
    Still green and orange lights flashing with no Compressor running...
  8. Re: Audi A6 Allroad compressor location
    #28
    Sep 2018
    Edinburgh
    Andy,
    Many thanks, your diagnosis was spot on!
    Turns out when I had cleaned the connector I had broken the little tab so it didn't reconnect properly.
    A couple of cable ties to keep the connector solidly together and the lights went out. I now have my car back!
    Thank you very much indeed, you are a true gent.
    Cheers,
    Chris
  9. Re: Audi A6 Allroad compressor location
    #29
    Ayrshire, Scotland
    18 Post(s)
    No problem, fault codes led us too it ��
    glad I could help
    best regards
    andy
  10. Re: Audi A6 Allroad compressor location
    #30
    Sep 2018
    Edinburgh
    OK, so things werent quite as straightforward as I'd hoped !
    The car did raise itself and go back to normal but then by afternoon today the rear had sagged again and the green and orange lights were flashing. MMI interface greyed-out. So I cleared the fault codes and the MMI came back, selected to lift and it worked fine. However the lights continued until it had got to the commanded height and then they went off.
    However one error remained, which was:
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 227
    Mileage: 300236 km
    Time Indication: 0
    Date: 2020.03.28
    Time: 19:45:36
    I presume as it went down then I have a leak somewhere? Does this error also point to another issue?
    Any help would br greatly appreciated !!!
    Many thanks,Chris
  1. Allroad air compressor vs. A6 rear self leveing compressor
    By g.suggy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-06-2012, 11:00 AM
  2. Replacing Air Con Compressor on 2002 Audi Allroad 2.5TDI AE
    By ceilidhalfie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-03-2012, 06:44 PM
  3. Please Help Audi Allroad door switch location ?
    By ivano24 in forum Chat - Completely Off Topic
    Last Post: 04-07-2009, 10:23 PM
  4. Noisy air compressor, Audi Allroad
    By safesurfer65 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 22-04-2008, 09:29 AM
  5. Audi Allroad (...to 2005) - Air Compressor
    By Cooperman in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-03-2008, 08:31 PM
