Thread: Can I replace the boot key cylinder?
Results 1 to 10 of 11
  1. Can I replace the boot key cylinder?
    Jan 2013
    N/A
    Hello B5 Avant drivers
    I noticed that my boot key slot is full of gunk and it doesn't function.
    The flap that supposed to cover the open slot look like it's been stuck open for very long time. I prodded with a BBQ skewer and I get loads of silver/metallic/candle wax ish gunk. I managed to clear the gunk enough so that 90% of the key enters the slot. And to my frustration, I forcefully turned the key and now the key slot twists freely… I think I broke the key cylinder… Otherwise, the boot locks with remote central lock and it works fine. Just the mechanical un/lock from the key cylinder is broken (I broke it).
    Do you think I get a second hand replacement of the key cylinder? An easy DIY job? Does it involve choosing the “right” cylinder to match my key, or do I need a VIN or code to find the right cylinder, etc?
    The boot key lock is (please discard of the tacky paint... it's on my "to do" list...):
    And the VAG catalogue gives me the part codes of either:
    8D9862055 - “lock cylinder with keys and housing “ * cannot be used to restore * * the one key locking * * system !! *
    107862055CA - “lock cylinder without key” * to retain the one key * * system the key code * * number and/or chassis * * number must be quoted * * when ordering *
    This sounds like a dealer job; any possibility of by-passing a dealer or hefty garage labour? I’d like to work on it myself if at all possible for a novice DIYer (I replaced rear washer jet, oil & filter, that sort of basic DIY).
    I am thankful of any advice to guide me to the right direction. Thank you!
    '11 VW B7 Passat Estate 2.0TDi CFFB (Current)
    '98 VW T4 Transporter 2.5TDi ACV (Previous)
    '99 Audi B5 A4 Avant 1.9TDi AFN (Previous)
  2. Re: Can I replace the boot key cylinder?
    Aug 2011
    Meath
    The cylinder is easy enough to change. You can buy off a dealer and your key will fit. One from a similar car at a breakers will also fit but, if they have a key they'll be reluctant to sell as the key is coded to the sell-able cluster/ecu. Even if you got one, you'd then have to carry 2 keys. Usually you just need to prove to the dealer that you own the car, give him your chassis number and prepay. Last one I got was £50.00
  3. Re: Can I replace the boot key cylinder?
    Jan 2013
    N/A
    Thanks Doctle.
    It makes sense. Roughly, how much do you think it'll cost to get the cylinder (can I replace just the cylinder or do I have to get something else to fully work?)?
    It's not that important to have the key cylinder to work, but it'll be nice to have it operational.
  4. Re: Can I replace the boot key cylinder?
    Aug 2011
    Meath
    For no key one just look in your local rag/free ads for someone breaking a similar car cost 5-10 pounds. I bought a new one that the key fitted for £50.00 it costs €80.00 in Ireland. It's not difficult to change if the cylinder has disintegrated just replace it nothing else is needed
  5. Re: Can I replace the boot key cylinder?
    Jan 2013
    N/A
    Brilliant thank you!
    I'll ring around breakers and dealers and see what responses I get.
    Out of curiosity, are car keys for the same model same year completely different from one another in terms of the teeth pattern? I wouldn't think that there are infinite amount of key pattern, but may be a handful of major pattern (say 5 or 10 major patterns) with subtle differences (100 minor differences); would a key with similar major pattern open another car with a key in the same major pattern? Or it doesn't work that way with a car key? Just a curious speculation so I don't have a solid evidence to support this.
    But thanks again and I'll post any update when I have some news
  6. Re: Can I replace the boot key cylinder?
    Jan 2013
    N/A
    Called the only breaker in town and another one in nearby, they don't have them. Fair enough.
    So I called the dealer; they can get me made for my key for £140.
    Okay nevermind, thank you...
    eBay I guess...
  7. Re: Can I replace the boot key cylinder?
    Aug 2011
    Meath
    What is he? A urine analyst? AUDI A4 O/S + N/S Door & Boot & Ignition Barrel Locks + Keys | eBay
    Look in yell.com for vag specialist breakers there's plenty
  8. Re: Can I replace the boot key cylinder?
    Jan 2013
    N/A
    HAHA! I want your brain. You just found me the right thing in 5min!
    That link is for Saloon B5, I'll check with my Avant to see if the boot cluster is the same as on the picture or not. Should'nt be too different should it?
    Thank you doctle!
  9. Re: Can I replace the boot key cylinder?
    Aug 2011
    Meath
    You can have my brain tomorrow I have a bottle of bourbon and 6 bottles of Stella for tonight!
  10. Re: Can I replace the boot key cylinder?
    Jan 2013
    N/A
    http://www.ebay.co.uk/itm/Audi-A4-B5...item4ac67f9326
    BOOM! £50. For saloon, though. Argh.
  1. How To need to replace clutch cylinder feed pipe
    By marsh369 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-09-2011, 11:43 PM
  2. Replace spring in flip key
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 12-05-2010, 09:27 AM
  3. Question A3 2004 Boot / Boot button on Key fob
    By youngybear in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 23-02-2010, 09:52 AM
  4. Replace CV boot
    By guv.c in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 09-03-2009, 06:37 PM
  5. How to replace boot VW badge on mark 4
    By dean-nez in forum Golf MK4 - 1999 - 2004
    Last Post: 29-07-2008, 04:29 PM
