Thread: Weird noise from front drivers side wheel!!
Results 1 to 10 of 12
  1. Weird noise from front drivers side wheel!!
    Dec 2009
    Manchester
    Just noticed this today.
    Basically its OK when driving in a straight line, but as soon as I start to turn left there is a sort of grinding sound! Pulled up at junction as thought it may be steering, so I turned it full lock whilst stationary and no noise. It also seems a bit clunky / crashy over bumps. Had a quick look around tyre and didnt see anything obvious! Any ideas?
  2. Re: Weird noise from front drivers side wheel!!
    DSG4ME Guest
    Start with the brake pads, could be a sticky caliper and one side is ok where the other side (same wheel) is gone totally.
  3. Re: Weird noise from front drivers side wheel!!
    Dec 2009
    Manchester
    You wont believe this!!!
    Two of the engine mounting bolts on drivers side of engine almost completely out!!!
  4. Re: Weird noise from front drivers side wheel!!
    Sep 2008
    SE London
    AFAIK they're stretch bolts? Get new ones. Have you had your cambelt done recently?
  5. Re: Weird noise from front drivers side wheel!!
    Dec 2009
    Manchester
    Quote Originally Posted by RichardSEL View Post
    Thats what the mechanic who looked at it said! And yes it was done earlier this year....by a VW main dealer!!!
  6. Re: Weird noise from front drivers side wheel!!
    Sep 2008
    SE London
    (groan)
    Main agents' service work is warrantied for two years. Either take it back, enquiring whether new stretch bolts will be fitted. Or take it elsewhere -ditto-
    There's a pattern emerging: last year had a body rust warranty and an engine recall done by main agents. Both needed returning.
    My indie tells me that when he was at main agent he got a complaint from manager that none of his work was being returned. I don't know how the finances of a main agent's service department work. Especially for returns
  7. Re: Weird noise from front drivers side wheel!!
    Dec 2009
    Manchester
    (groan)
    Its going back this morning...so hopefully they will put it right!!!
  8. Re: Weird noise from front drivers side wheel!!
    Dec 2009
    Manchester
    All fixed and back to normal. VW were very apologetic.
  9. Re: Weird noise from front drivers side wheel!!
    Sep 2008
    SE London
    Did you enquire whether they use stretch bolts at the engine mounts?
    If so, and they havn't changed them, then they could come loose again
    Dunno if likely though, havn't noticed anyone else mention them. I've only
    had one cambelt change and indie I used (VW Mastertech) didn't mention
    them, or charge me for fresh bolts for my tFSI 2.0L
    Dunno if you've seen this horror thread about broken engine mount after cambelt change
    UKpassats.co.uk • View topic - whats that noise ??
  10. Re: Weird noise from front drivers side wheel!!
    Dec 2009
    Manchester
    I did mention it when I took it in. The service manager said that they had been replaced and they have checked and there is no damage. Overall very pleased with their response.
  1. Replies: 1
    Last Post: 09-08-2012, 10:11 PM
  2. knock sound from front drivers side wheel area
    By churp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-06-2012, 06:14 PM
  3. Clicking Sparking Noise coming from Drivers side wheel arch.
    By afghandaz in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-05-2010, 08:24 PM
  4. Please Help Huge Pothole - WHACK - knocking noise front drivers side
    By danclyon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-05-2010, 09:43 AM
  5. Squeaky noise from drivers side front wheel and harsh gear change (triptonic)
    By jasear in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-04-2008, 02:20 AM
