Facelift Cars - '58 plate onwards
1. Enabling Gauge Test/Needle Sweep
[Select]
[17 - Instruments]
[Coding - 07]
[Long Coding Helper]
Click on the second byte in the list.
Check the box for "Gauge Test/Needle Sweep active"
[Do It!]
2. Hidden menu in 3G MMI
[Select]
[5F - Information Electr.]
[Adaptation - 10]
Choose Channel 6
change value from 0 to 1
[Save]
[Done]
3. Enabling VIM (Video in Motion)
[Select]
[Control Module 5f]
[Advanced ID - 1A]
Make a note of the serial number and decode using MMI VIMGen
[Security Access - 16]
Enter the code generated above
[Do it!]
[Adaptation - 10]
Choose Channel 48
change value from 0 to 255
[Save]
[Done]
Restart MMI
4. Enable Battery Meter once #2 has been completed
Hold in CAR + SETUP
car
carextdevicelist
check "Battery"
return
carmenuoperation
set "Battery" to 5
return
Restart MMI
5. Enable Bluetooth on MMI 3G
[Select]
[Control Module 5f]
[Adaption - 10]
Channel 06
New Value = 1
Test, Save, Done.
Now go into the Hidden Menu, see 2. Hidden menu in 3G MMI
Diagnose>Settings>Tel Settings Misc
Change the available options to - [no WLAN/no NAD/BT/HFP] 4/16
Restart MMI (Hold in SETUP + Centre MMI Knob + Upper Right Inner Key]
[Select]
[Control Module 5F]
[Adaption - 10]
Channel 17
New Value = 1
Test, Save, Done.
If you have Nav fitted, the microphone will be present, if no Nav is fitted then you need to purchase microphone pack 4L1 (or 4L2) 035 711 G
6. Enable AMI (Audi Music Interface) on MMI 3G (after fitting the hardware)
[Select]
[Control Module 5F]
[Adaption - 10]
Channel 6
New Value = 1
Go into hidden menu, hold in CAR + SETUP ... WARNING DO NOT CHANGE ANY VALUES YOU DON'T KNOW OR ELSE BAD BAD THINGS MAY HAPPEN
Diagnosis -> Settings -> Audi Music Interface (AMI) set to 7/8
Press RETURN and come out of the hidden menu.
Press MEDIA, Source and test the AMI.
7. Visual Parking Aid - if supported
[Select]
[76 - Park Assist]
[Coding - 07]
Change second digit to '2'
Example - Original code is 0001106 ... New code is 0201106
[Do it!]
Restart MMI and select reverse
8. Enabling Lap Timer/Boost Guage/Oil Temp
[Select]
[17 - Instruments]
[Coding - 07]
Check the box for "Lap Timer active"
9. Enable Rear DRL (Scandinavian Lights)
[Select]
[09 - Cent Elec]
[Coding - 07]
Change the 7th digit (ie the last one) to
2
[Do It!]
10. Enable Passenger Mirror Dipping
[Select]
[52 - Passenger Door]
[Coding - 07]
Byte 4, bit 3 - Position memory for reverse gear dipping active
Tick the box
[Do It!]
Test by turning ignition off and then on, select the passenger side on the adjustment switch and select reverse.
