Thread: Fault found on scan, any ideas?
  1. Fault found on scan, any ideas?
    Aug 2012
    Hampshire
    Decided to give the car a scan today, its driving fine, no lights etc.
    Scan is showing the following fault.
    1 Fault Found:
    10086 - Neutral Gear Sensor
    P15A1 00 [032] - Implausible Signal
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 151460 km
    Date: 2013.09.28
    Time: 15:25:31
    Any ideas, I saved the log then tried to clear it but it still shows so I am now wondering if anyone has seen it before and if its something I can sort myself.
    Had a quick google with it, but didnt find much.
    And for reference, mine is the 6 speed, not an auto.
    EDIT * Also when I started the car yesterday, I got the warning that the battery was low and would charge whilst driving. Intrestingly, the battery meter was still showing 100%, but I never got that warning today, so not sure if its an electrial glitch?
    2013 A6 2.0TDi S-line
    Fully registered VCDS in Portsmouth & surrounding areas & fault diagnostics/resets on most other makes.
  2. Re: Fault found on scan, any ideas?
    Aug 2012
    Hampshire
    Just a little update on this.
    I pulled the gear lever gator up, and had a little look underneath and could not find anything that stood out, so I reached in under the stop/start button and gave a small push to make sure the connector was on tight, and the fault has gone on the scan, so fingers crossed thats all it was.
    Time will tell!
    0 2 0
  1. any ideas on below scan
    By maccayzf in forum VCDS - Help Requests
    Last Post: 08-10-2013, 08:48 AM
  2. Airbag Fault VCDS scan
    By hitachizx in forum Golf MK4 - 1999 - 2004
    Last Post: 04-01-2013, 08:32 PM
  3. Aircon problem found on scan
    By ChA6dders in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-12-2012, 11:48 AM
  4. A6 (C5) fault scan
    By kite in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-11-2009, 03:28 AM
  5. Fault found after vag-com scan. Help??
    By ickleric in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-02-2008, 11:46 PM
