Thread: s6 brakes 1997
Results 1 to 9 of 9
  1. s6 brakes 1997
    Oct 2013
    woodbridge
    HI I have got my old s6 auto Avant back on the road it has been off for 2 years and the brakes seem to be warped I thought they might sort themselves out but after 200 miles they are still the same. At £50 a disk and £40 for pads is there a cheaper way round or is it time to spend more money ?
  2. Re: s6 brakes 1997
    Oct 2005
    It's a £40k+ car sadly, things are going to be expensive.
    The one area I wouldn't cheap out on is the brakes.
    EDIT:
    ECP have a 25% sale if that helps you in any way - http://www.eurocarparts.com/
    If you go for Pagid all round, you'll get the whole lot for £260
  3. Re: s6 brakes 1997
    Pembrokeshire
    22 Post(s)
    do you have a layer of rust on the discs or a ridge of rust around the inner or outer edge. if so, has part of it chipped off ? if so, clean them up with a chipping stick and see if they are better. if they were not warped when you last drove it then 2 years of sitting there hasn't caused them to warp.
  4. Re: s6 brakes 1997
    Oct 2013
    woodbridge
    I don't think that will work my mate cleaned them up to get it though the MOT but I will take the wheels off and have look next time the sun makes an appearance
  5. Re: s6 brakes 1997
    Pembrokeshire
    22 Post(s)
    i bet he has left some bits of rust on an edge. as this hits the pad it causes a judder that feels just like a warped disc.
    2 1 0
  6. Re: s6 brakes 1997
    Oct 2013
    woodbridge
    that would make sense as I am sure I had new discs put on about a year before I took her off the road and I don't do many miles
  7. Re: s6 brakes 1997
    Aug 2011
    Meath
    As Zollaf says a good clean. I'd change the pads too
    1 1 0
  8. Re: s6 brakes 1997
    Pembrokeshire
    22 Post(s)
    discs are large areas of steel. they get wet and wet causes rust. the only thing stopping rust is heat from braking. not using a car, especially when the air is damp and discs get cold and cold steel attracts condensaton, and this leads to rust. wheels off, look at the discs but not just the outer surface, have a good look at the inner edge as well. chances are they are fine, just got a build up of rust.
    1 1 0
  9. Re: s6 brakes 1997
    Oct 2013
    woodbridge
    thanks mate looks like I have a busy weekend ahead I will let you know how I get on
  1. Replies: 0
    Last Post: 26-12-2010, 04:08 PM
  2. Help 1997 1.6 A4
    By ashman86 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-06-2009, 08:59 PM
  3. Question Sharan 1997 front brakes
    By macca73 in forum Touran - Sharan - Caravelle
    Last Post: 20-08-2008, 09:26 AM
  4. 1997 A6 Cab Brakes
    By rudivisser in forum 80 - 90
    Last Post: 09-12-2007, 07:06 PM
  5. Upgrade A6 brakes to S8 brakes
    By mmm777 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-09-2007, 10:15 PM
