Thread: Auto dimming side mirrors, 6XF replaced with 6XL
Results 1 to 10 of 16
  1. Auto dimming side mirrors, 6XF replaced with 6XL
    Jun 2011
    Bitola, Macedonia
    Hello
    My car originally had 6XF side mirrors: with memory function, electrically foldable/adjustable/heated. Since I found my car one morning missing both side mirrors, i replaced the left one
    with a 6XL: with memory function, automatically dimming, electrically foldable/adjustable/heated from ebay.
    My question is: since both the 6XF and the 6XL have the same number of wires (2 cables, 7 wires each and identical pin layout) should the auto dimming option work without making any changes,
    and if not, what can I do to get the mirror to auto dim?
    Thank you
  2. Re: Auto dimming side mirrors, 6XF replaced with 6XL
    46 Post(s)
    It's the glass itself that dims so you will have to get a replacement dimming glass mirror.
  3. Re: Auto dimming side mirrors, 6XF replaced with 6XL
    Jun 2011
    Bitola, Macedonia
    Is there any way to test if the glass is worknig, it's not discoloured (brownish)?
  4. Re: Auto dimming side mirrors, 6XF replaced with 6XL
    46 Post(s)
    Is there a part number on the back of the glass?
  5. Re: Auto dimming side mirrors, 6XF replaced with 6XL
    Jan 2012
    Coding Something
    Dimming glass of old has the black plastic all the way round it, the newer type doesn't have the plastic, but has a dotted line all the way round about 5mm in from the glass edge, if you haven't got either, then its not dimming glass.
  6. Re: Auto dimming side mirrors, 6XF replaced with 6XL
    Jun 2011
    Bitola, Macedonia
    The glass is dimming, the back side looks like this (this is a web photo of an A4 glass, but except for the shape, the layout is the same).
    Also in the car manual i read that if i turn on the interior lighting, or select reverse, auto-dimming is cancelled. I assume this is controlled by turning the power to the glass on or off.
    So since both 6XL and 6XF have the same number of wires, maybe the one that powers the auto-dim is not connected in the car.
    I will try an measure the voltage on the black connector.
    Regards.
  7. Re: Auto dimming side mirrors, 6XF replaced with 6XL
    Jan 2012
    Coding Something
    Probably find there are no wires from the mirror down to the door pillars, this is standard through allot of chassis, although some are prewired if not fitted anyway, as I found in my S3 8L years back.
  8. Re: Auto dimming side mirrors, 6XF replaced with 6XL
    mjhamilton Guest
    Bit of a tangent but when I fitted my Ali mirror housings I removed the mirrors and found 3 cables - 2 where connected for the mirror heating element but the third which was top close to the door was tucked away on both sides
    Anyone thing that dimming mirrors is just the glass type and I could just upgrade myself or is there more to it?
  9. Re: Auto dimming side mirrors, 6XF replaced with 6XL
    Southern County Softy
    20 Post(s)
    Quote Originally Posted by mjhamilton View Post
    You might want to check the price of the dimming glass before considering the retrofit.
    Sent from my GT-I9305 using Tapatalk
    A4 2.5 tdi QS (mapped)
  10. Re: Auto dimming side mirrors, 6XF replaced with 6XL
    mjhamilton Guest
    That is the substance behind my theory
    I am guessing it's not cheap then
  1. Question Heated Wing Mirrors / Door Mirrors / Side Mirrors / Side Mounted Rear Viewing Devices
    By simonrk57 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-05-2017, 07:53 PM
  2. Auto Dimming Mirror
    By Jamiem in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-02-2011, 12:23 AM
  3. Auto dimming mirror
    By doublem_1 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 04-09-2010, 08:27 PM
  4. Retrofiting Auto dimming side mirrors.
    By katallozi in forum Audi A3 - Archive Topics
    Last Post: 22-04-2009, 01:22 AM
  5. Dimming Door Mirrors
    By ian397995 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-01-2008, 11:00 PM
