Thread: Anyone know if this is covered by warranty (AA)
Results 1 to 10 of 16
  1. Anyone know if this is covered by warranty (AA)
    May 2007
    SOUTH LONDON
    Hi all,
    Car is in garage at the moment with the problem being found out as the throttle body, I am waiting for the call from the garage who will be speaking to AA warranty (I have the premium cover) however little bit unsure if I am covered..
    Also Glow Plugs need replacing due to the Throttle body. not sure if they will replace these under warranty either.
    Anyone had experience of warranty claims on a throttle body?
    Im not sure just waiting for this bloody call to say YES.
    there paperwork is a little dubious and as usual doesn't give an easy answer.
  2. Re: Anyone know if this is covered by warranty (AA)
    46 Post(s)
    My Audi Extedened warranty has a section and says what's excluded but that just says wear and tear due to it bent the same as the factory warranty
    My experience of aftermarket warranties was poor, always assume they won't cover the fault then it's not too hard a blow when you're told rejected.
  3. Re: Anyone know if this is covered by warranty (AA)
    May 2007
    SOUTH LONDON
    Thanks A6_chris,
    I got a feeling it is not covered too, like you say expect the worst.
    Will let ppl know once I get the call by the sounds of it, hopefully its a yes but expecting that its no and if it is lets see if I can fight it.
  4. Re: Anyone know if this is covered by warranty (AA)
    May 2007
    SOUTH LONDON
    Just got the call..
    Its Covered
    Phew...
  5. Re: Anyone know if this is covered by warranty (AA)
    May 2007
    SOUTH LONDON
    Car back in again. they replaced the whole intake part with the throttle body first time, but the warning lights show up intake manifold runner line 2 I think it said.. so it could well be the 2nd throttle body.
  6. Re: Anyone know if this is covered by warranty (AA)
    Feb 2009
    Glasgow UK
    Well, hopefully that should be covered too.
    Probably a good thing that they've failed needing to be replaced, the warranty has done its thing and saved you many £££
    Hope to hear
    1 1 0
  7. Re: Anyone know if this is covered by warranty (AA)
    Dec 2010
    Wiltshire
    Great value for money then, most insurances not worth... well you know what.
  8. Re: Anyone know if this is covered by warranty (AA)
    May 2007
    SOUTH LONDON
    Got car back, still not fixed, the garage said that he checked the part they had replaced and it was definitely that part that was not working properly he is not sure as the error codes keep coming back with different errors but it related to the intake runner 2. I was thinking could this be that the part has to be registered/programmed in? the car was performing lovely for one day before it turned back.
    I am taking it back to them on Monday as the guy who I was dealing with is back then and I will go through warranty again, but just thought could the re-programming part be the problem?
  9. Re: Anyone know if this is covered by warranty (AA)
    May 2007
    SOUTH LONDON
    Just received call that it is the 2nd intake ... also it is good news that this is also covered..
  10. Re: Anyone know if this is covered by warranty (AA)
    46 Post(s)
    to AA!
  1. Question Is lacquer covered bv paintwork warranty?
    By curiousgeorge in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-04-2010, 09:12 AM
  2. Is this covered in my warranty ?
    By prodrive305 in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 10-04-2010, 11:01 AM
  3. New Condenser not covered under warranty
    By robhinesjetta in forum Jetta MK3 - 2005 - 2013
    Last Post: 23-07-2009, 11:39 PM
  4. Question Lacquer Peel - Will it be covered by warranty??
    By GavManMoon in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-10-2008, 03:57 PM
  5. expired Warranty on a laptop, but am i still covered?
    By dansansome in forum Chat - Completely Off Topic
    Last Post: 11-03-2008, 04:44 PM
