Thread: Vagcom login codes !!!!
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: Vagcom login codes !!!!
    #11
    May 2007
    knee deep in clunge
    14 Post(s)
    try again with the channels 5,7,8 and see if that helps if not you need a higher version
    [17 - Instruments]
    [Adaptation - 10]
    Enter the correct channel from the chart below in "Channel Number"
    [Read]
    The "Stored Value" is the current value for that channel.
    Enter the "New" value of from the chart below.
    [Test]
    [Save]
    So, for example, to reset the OIL reminder in a Sharan, save a "New" adaptation value of 00150 to channel 10.
    Channel Indicated on Display Contents "New" Adaptation value to reset
    05
    OIL Distance which can be reset 00150
    06
    INSP Time which can be reset 00360
    07 IN 01 00000
    08 IN 02 00000
    Note: Distance is in 100's of km. Time is in days.
    Oil change service every15000 km Reset Channel 05 & 06
    Inspection every 12 months Reset Channels 05, 06, & 07
    Inspection service every 30000 km Reset Channels 05, 06, 07, & 08
    vag diagnostics, retrofits and general repairs
  2. Re: Vagcom login codes !!!!
    #12
    Jun 2007
    Bristol
    cheers a8 , will give it a whirl tomorrow hopefully,
    I did manage to reset the oil service via the trip reset button and ignition on combination a few months ago m8 , but done another oil change recently, since that 1st reset i have no info on the dash read out now just the trip in miles ???
    , so i wanted to go in and see it with vagcom if poss !!!
    all seems abit strange really
    MK5 Golf TDI 2.0ltr GT Sport in Black
  3. Re: Vagcom login codes !!!!
    #13
    May 2007
    knee deep in clunge
    14 Post(s)
    The list of adaption channels will work paul,have a faith
  4. Re: Vagcom login codes !!!!
    #14
    Jun 2007
    Bristol
    ok , got into the channels are sure enough the values given match those you talk about a8 ,
    However when i go to change them , after confirming i want the change of values , a box pops up and says
    Unregistered Version
    Please contact your supplier
    to Register this product
    DAm dam dam dam
    Would love a registered version , but i aint got £50 spare
    So i guess im stuck then , until i get a registered version of vagcom
  5. Do oceny strona www
    #15
    Sep 2017
    Polska
    Witam serdecznie, Chia³bym prosiæ o ocenê mojej strony internetowej nowe loga firm Chodzi mi o ocenê szablonu strony. Jeœli temat da³em w z³ym miejscu to proszê o przeniesienie. Jesten nowy na forum Pozdrawiam
  6. Re: Vagcom login codes !!!!
    #16
    Jun 2017
    London
    Hello there
    I need login code for ecu engine different from 12233 because
    I have two Audi A6 c5, one is 1.9tdi 2001 115hp where 12233 code working perfectly, but I also have
    Audi A6 c5, 2.5 TDI Quattro 2004 180hp and 12233 code doesn't work for this model, so is it there any other codes.
    Regards
  7. Re: Vagcom login codes !!!!
    #17
    Jun 2017
    London
    Quote Originally Posted by a8 tech View Post
    if you are trying to reset the service indictor you must do it via dash insert select 17 then adaption 10 channel 2 and change the value to 0 and save.12233 is for engine ecu settings for egr and fuel and timing as i have posted on here for pd fueling issues
    Hello there
    Regards
  1. vagcom codes.
    By M4YTY in forum Chat - Completely Off Topic
    Last Post: 24-05-2007, 09:29 AM
  2. VAG COM Login codes
    By Dune in forum Audi A4 - Archive Topics
    Last Post: 10-05-2007, 11:34 PM
  3. Login Code
    By jamie211983 in forum Passat - Archive Topics
    Last Post: 22-04-2007, 12:30 PM
  4. vagcom codes from my mk4 golf help
    By dreamworx in forum Golf MK4 - 1999 - 2004
    Last Post: 23-11-2006, 03:14 PM
