Thread: VCDS needed in Bristol
Results 1 to 10 of 16
  1. VCDS needed in Bristol
    minty2013 Guest
    Hello,
    Im looking for someone in Bristol area with VCDS to work on my 2002 Passat TDi.
    I have the Micro-CAN but unfortunatly doesnt work on my car so would like someone to read and clear codes, disable selective unlocking, enable comfort indicators etc.
    Anyone about who could assist?
    Thanks Minty
    Sent from my GT-I9505 using Tapatalk 4
  2. Re: VCDS needed in Bristol
    46 Post(s)
  3. Re: VCDS needed in Bristol
    minty2013 Guest
    Ta. I have looked but cannot PM them yet
  4. Re: VCDS needed in Bristol
    46 Post(s)
    Ah that's right, I can PM them and get their attention for you until you have enough posts?
  5. Re: VCDS needed in Bristol
    minty2013 Guest
    If thats allowed that would be great.
    I also need to add myself to the list as VCDS Micro-CAN user to offer code reading etc
  6. Re: VCDS needed in Bristol
    46 Post(s)
    Yep that's no problem, I'll do that now.
    I'll also add you to the user map too.
  7. Re: VCDS needed in Bristol
    minty2013 Guest
    Brill thank you.
    Really miss comfort indicators after driving the B6 Passat, hopefully just a case of ticking an option and no hardware required!
  8. Re: VCDS needed in Bristol
    46 Post(s)
    I think mycarsavw added comfort indicators to his b5, he's online so he might see this.
    I'll go search anyway.
  9. Re: VCDS needed in Bristol
    minty2013 Guest
    Mines a March 2002 car, does that make it a B5.5?
  10. Re: VCDS needed in Bristol
    46 Post(s)
    I think the 5.5 was a facelift, no?
    This is what you're looking for - UKpassats.co.uk • View topic - Comfort indicators
    Will continue to search for when Sam mentioned it on here.
    Quote Originally Posted by mycarsavw
    I added this option to my Passat by fitting a small module that taps into the hazard relay circuit
    I set up a group buy on another forum and sold in excess of 50 modules.
    I went direct to the makers - (Home - it's called a Komfortblinker).
    I've had mine a few years now and it's the single most useful mod I've carried out.
  1. Vcds in Bristol
    By mkc in forum VCDS - Users Locations
    Last Post: 03-09-2013, 11:28 AM
  2. VCDS help Bristol/Staffs
    By ChA6dders in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-11-2012, 06:58 PM
  3. VCDS in Bristol Area
    By driventodespair in forum VCDS - Users Locations
    Last Post: 08-07-2012, 05:41 AM
  4. Anyone with VCDS in Bristol area?
    By robs7 in forum VCDS - Help Requests
    Last Post: 16-05-2012, 07:59 PM
  5. Help needed in Bristol
    By njek in forum VCDS - Help Requests
    Last Post: 01-02-2010, 09:46 PM
