Thread: Front wiper motor and linkage
  1. Front wiper motor and linkage
    Aug 2013
    Kew
    Hello
    I have a year 2000 A6 Avant 2.7T, which is now exhibiting the wiper linkage "arthritis" problem. So having viewed a few Youtube videos, thought that looks relatively easy to change.
    It's a tight squeeze to remove the wiper linkage and motor assembly - very tight indeed. I had to loosen the cpu housing in order to get the extra space to do the job. The linkage assembly is totally seized so will try to dismantle and re-assemble using as much WD40 and copper grease as is required. I'll be able to check the motor operation once I remove the motor from the linkage assembly. I'm not done yet.
    So the car is minus, wipers, wiper motor and linkage assembly, whilst I try to correct this problem. Interesting point though. When putting the key back in the ignition, the car does not turn over and start. So without the wiper motor in situ, Audi's cpu may do initial checks and then "says no" when it sees no wiper motor in place, OR I might have knocked something or disturbed something else in the process.
    Any advice is widely appreciated.
    best regards
    Chris
  2. Re: Front wiper motor and linkage
    Ayrshire, Scotland
    18 Post(s)
    you will probably have done what i did!!, when pulling the ECU you will have undid a connector by mistake, i did this i think it was a red one, but basically check in the hole under the ecu to see what you may have accidentally unplugged, there are a few, it is nothing to do with the wipers not being there!!
    when i turned the key it was dead, the dash lit up but no click for a starter, in my case i had the car back together before i notheced this, wipers back on the lot!! i had to strip it back to get the ecu cover off and lift the ecu a little to find it
    to stip the wiper linkage there is a small circlip holding the shaft in place, remove it and its washer and try to take the shaft out, i had to use heat
    regards
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  1. Front wiper linkage compatibility
    By Bigpiug in forum Touran - Sharan - Caravelle
    Last Post: 19-02-2011, 02:24 PM
  2. Question A3 Wiper motor and linkage
    By paulkelly77 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 15-07-2009, 05:21 PM
  3. Question Average time to failure for A4 Windscreen wiper motor and linkage
    By Evsie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-07-2008, 10:30 AM
  4. Sharan Front Wiper motor linkage
    By siloverbuzzard in forum Archive posts
    Last Post: 23-12-2007, 02:56 PM
  5. [Help] Front wiper linkage
    By Jose in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-07-2007, 06:11 AM
