Thread: DPF, glow plug and engine management light all showing
Results 1 to 10 of 15
  1. DPF, glow plug and engine management light all showing
    Aug 2012
    nottingham
    hi (its my first posting sorry if its in the wrong place)
    on my audi a4 b8 2008 i did a manual regen to clear the dpf as the dpf sign was displayed 2 week ago, but now the dpf, glow plug sign (flashing) and engine management light is showing car went into limp mode.
    had the codes done which:-
    5188-P2463:- DIESEL particle filter:- excessive soot accumulation – no signal communitaion
    5162-p0471 :- exhaust pressure sensor 1 (g450) implausible signal – open or short to plus
    do i need to get the g450 pressure sensor changed and forced regen?? or do the codes show some other problem? the codes have now been cleared and the car is driving normally, can i still drive the car or will it block the dpf more if i drive it?
    generally how much is it for the sensor change and forced regen? and do i have to get a forced regen done or can i just do a manual regen myself once the sensor has been changed?
    thank you
  2. Re: DPF, glow plug and engine management light all showing
    Jul 2008
    Have a look a few threads below - this has been covered in the last few days. Help!! Major panic!
    1 2 0
  3. Re: DPF, glow plug and engine management light all showing
    Aug 2012
    Hampshire
    Sounds like the infamous sensor. If you have access to VCDS for the forced regen, you can change it yourself quite easily. Mine was changed by my local specialist, but thats only because I was due a major service and a couple of little bits just as mine packed up, but it was not overly expensive.
    Breaking down my reciept, the genuine sensor was £49.83, and £55 to change and regen.
    I was advised not to keep driving my car until it was changed, to prevent damage to the dpf filter, as if the sensor is not working, then it will not regen.
    2013 A6 2.0TDi S-line
    Fully registered VCDS in Portsmouth & surrounding areas & fault diagnostics/resets on most other makes.
    1 1 0
  4. Re: DPF, glow plug and engine management light all showing
    46 Post(s)
    Quote Originally Posted by mhurer View Post
    On the ball, new sensor and forced regen needed.
  5. Re: DPF, glow plug and engine management light all showing
    Aug 2012
    nottingham
    Quote Originally Posted by Dieseldoos View Post
    thanks for the quick reply i live in Nottingham i've been given quotes from two audi specialist (for sensor change and regen) :--
    german automotives derby :- £150+vat = £180
    autotechz nottingham :- £143.80 including VAT
    both sound very expensive compared to you £104.83
    anybody know any other garages around Nottingham or near nottingham area that can replace the sensor and do a regen, is it also true that the senors need to be adapted via VCDS??
  6. Re: DPF, glow plug and engine management light all showing
    46 Post(s)
    CR Enterprises - Contact Us
    Crasher (Steve, the owner!) is a sponsor of the forum, highly rated by lots of people. Mention the forum and I'm sure he will do you a deal.
    And yes the sensor needs to be re-calibrated.
    1 1 0
  7. Re: DPF, glow plug and engine management light all showing
    Aug 2012
    nottingham
    ok will do on Tuesday since Monday is bank holiday
    thanks
  8. Re: DPF, glow plug and engine management light all showing
    Jan 2013
    Scotland
    11 Post(s)
    the sensor is £59 from Audi. I bought mine from my local dealer a week or so ago, in fact thats my panic thread that posted above! lol the sensor is very accessible and literally took 90 seconds MAX to replace. my grandmother could do it seriously. I got a quote from a local indi garage of 20 quid to adapt the sensor but then i kinda worked out my self with my own vcds. took about 20 mins to regen to 0.1g from 28g.
    Audi A6 3.0 BiTDI Black Edition
    2 2 0
  9. Re: DPF, glow plug and engine management light all showing
    Aug 2012
    nottingham
    thanks gdallas
    i am looking to get VCDS so that i can adapted the G450 sensor and do a forced regen will any of the following do the job :-
    <removed>
    please advice if any of this will do the job or if i can download VCDS from somewhere and just buy the cable
  10. Re: DPF, glow plug and engine management light all showing
    Sep 2007
    Windsor
    The software can be downloaded from Ross-Tech but you will need HEX-USB+CAN interface to go with it. The ones you are looking at on Amazon are not the genuine VCDS and may not work properly or even at all -avoid! You can buy the genuine interface from the likes of Gendan or ilexa. Alternatively check out the VCDS User Locations for someone with VCDS nearby who could help you out.
    2 1 0
  1. Please Help dpf flashing glow plug and eng management light on??
    By ahsanx in forum Golf MK5 - 2004 - 2009
    Last Post: 17-01-2019, 09:52 PM
  2. Golfgt tdi 170 glow plug light +Dpf light please help!!
    By veedub76 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-01-2013, 10:07 AM
  3. DPF, Flashing Glow Plug and Engine Mang Light on..
    By Imizz in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-08-2011, 01:06 PM
  4. No glow plug(engine management?) lamp: T4,2.4d 2000 model
    By Black Angus in forum The Commercial Range
    Last Post: 17-12-2007, 04:34 PM
  5. Glow plug light not showing, and ECU not accessable.
    By justinbaker in forum The Commercial Range
    Last Post: 07-08-2007, 04:24 PM
