Thread: Reversing camera
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
  1. Reversing camera
    Jan 2011
    Stafford, UK
    Rather than hijack AlyM's post - Dash Camera - Page 2
    I like his solution for a reversing camera.
    I want to keep my MMI parking display so this looks an ideal solution.
    Has anyone done a installation project on this ?
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
  2. Re: Reversing camera
    Apr 2013
    Stirling
    11 Post(s)
    I''ve obviously done it and I've got a little switch under the dash (next to the bonnet release) to turn it off and on! Here is the camera...
    Sent from my GT-I9300 using Tapatalk 4
  3. Re: Reversing camera
    Apr 2013
    Stirling
    11 Post(s)
  4. Re: Reversing camera
    Apr 2013
    Stirling
    11 Post(s)
    This is the camera I used...
    http://pages.ebay.com/link/?nav=item...d=280893709490
    I went for that one so I could use the LED number plate lights.
    Unlike this one below where you have to use the LED that's built in. Causing both sides to be differently illuminated...
    http://pages.ebay.com/link/?nav=item...d=251205035721
  5. Re: Reversing camera
    Jan 2011
    Stafford, UK
    Quote Originally Posted by AlyM View Post
    I like the camera that fit into the number plate light.
    There has to be a way of using the reverse gear to power it.
    Would a relay connected to the reversing lights work to save having a switch, if so any of you electrical genii know how it could be done & where to take the power from ?
  6. Re: Reversing camera
    Apr 2013
    Stirling
    11 Post(s)
    I initially did but was getting a lot of static so gave up in the end and just added the switch...
  7. Re: Reversing camera
    46 Post(s)
    If you're wanting OEM integration then you'll need to add the TV tuner and this is big bucks.
    I was going to fit the OEM camera to my A3 with RNSE and I needed:
    - OEM Camera integrated into the boot handle
    - Loom from camera to control module
    - R8 camera control module
    - Loom from module to RNSE.
    Obviously the RNSE is different but the camera on MMI routes thru the TV tuner then forward into the car so unless you want to spend ~£1k+ getting a TV tuner, antennas, cabling, camera and loom for that then you'd be best going aftermarket imo.
  8. Re: Reversing camera
    Jan 2011
    Stafford, UK
    I don't want to go OEM Chris, I want to maintain my MMI display with front / rear distance display. Thats what I like about AlyM's set up, - best of both worlds.
    This is how I tapped into reversing lights when I installed rev sensors on my 2008 A6
    If I could do the same to activate a relay and tap into a power supply, What do you think?
    If I had probs I could always go with a switch like Aly.
  9. Re: Reversing camera
    Apr 2013
    Stirling
    11 Post(s)
    It will work. The good thing about the screen is it trips on automatically and goes into reverse mode on screen!
  10. Re: Reversing camera
    Jan 2011
    Stafford, UK
    Thanks Aly. I'll start getting the stuff together.
    How did you rout the wires from camera to monitor ?
  1. Reversing camera
    By sterling01 in forum A8 - S8 - V8
    Last Post: 01-01-2013, 06:43 PM
  2. Question Reversing Camera
    By A4 Lad in forum In Car Entertainment
    Last Post: 15-01-2012, 10:28 PM
  3. Reversing Camera
    By billcoleman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-01-2011, 12:09 AM
  4. Reversing Camera
    By tsunami in forum Golf MK4 - 1999 - 2004
    Last Post: 28-08-2008, 07:44 PM
  5. reversing camera?
    By ickleric in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-05-2008, 12:34 PM
