Thread: How do you jack up an A8? I want to fix the parking brake.
Results 1 to 10 of 11
  1. How do you jack up an A8? I want to fix the parking brake.
    Nov 2012
    Cardiff, UK
    This question has been burning in my brain for a while now.
    When it comes to jacking up your A8, what do you use?
    More specifically I wish to gain access to the parking brake and suss it out.
    Is it safe to disconnect wires or do you have to turn something off or put the car into a particular mode or disconnect battery?
    I know the car needs to be put into jack mode.
  2. Re: How do you jack up an A8? I want to fix the parking brake.
    46 Post(s)
    For cars with air suspension you need to put it in jacking mode, I believe this is available in the CAR menu on your mmi.
    Your choice to disconnect the battery afterwards, just a 10mm bolt on the negative although I don't think it would be necessary if you're just looking as you might need vcds to release the back brake.
  3. Re: How do you jack up an A8? I want to fix the parking brake.
    Aug 2011
    Meath
    There's jacking points behind the front wheels and in front of the back wheels. Use a 2 ton trolley jack and if you're going under it use axle stands
  4. Re: How do you jack up an A8? I want to fix the parking brake.
    Nov 2012
    Cardiff, UK
    I have VCDs.
  5. Re: How do you jack up an A8? I want to fix the parking brake.
    Sep 2011
    Lurking over a keyboard ...
    Once you've jacked car via jacking points, place axle stands on subframe front/rear ...
    On my A6 the front subframe is easily visible but rear is under some underbody trim ...
    Just in case the front subframe will be under engine item 20 this diagram Link:- http://www.jimellisaudiparts.com/sho...tring=subframe
    Rear is item 1 this diagram Link:- http://www.jimellisaudiparts.com/sho...g=rear%20frame
    I picked the points on subframe closest to jacking point, say on front item 21 on 20 and rear item 2 on 1 ...
    Hope it make sense ...
    1 1 0
  6. Re: How do you jack up an A8? I want to fix the parking brake.
    Sep 2011
    ... if you're just looking as you might need vcds to release the back brake.
    Quote Originally Posted by a8starr View Post
    I have VCDs.
    For now view this ...
    And this Link:- http://wiki.ross-tech.com/wiki/index..._Parking_Brake
    will dig up more info tomorrow ...
  7. Re: How do you jack up an A8? I want to fix the parking brake.
    Sep 2009
    NW England
    I'm a bit puzzled by this, you're wanting to dive into some very complex electronic brakes, but don't know how to jack up the car?
    That is surprising
    2006 A8 4.2 | Adaptive Cruise | Bose | BT | Pwr Doors | Satin Nappa Lthr | 20" Alloys
    Xenon Plus | Analogue & Digital TV | Comfort Seats | Sport Suspension
    Heated MFSW with paddles | Solar-Panel Sunroof | Electric Rear & Side blinds
    Heated F&R seats | Auto Boot Lid | 1-touch Mem | Advanced Key | Inside & Outside lighting pckge
    Retrofitted |Towbar |Rev+Front Cam |
    MMI 5570 |AMI |2014 Maps |Illuminated sills |RSE |S8 CF Trim |TPMS
  8. Re: How do you jack up an A8? I want to fix the parking brake.
    london/ UK
    Quote Originally Posted by Micha_elD View Post
    That is surprising
    My thoughts exactly !
  9. Re: How do you jack up an A8? I want to fix the parking brake.
    Nov 2012
    Cardiff, UK
    That is surprising
    this is why I asked the question. I am not a car mechanic and fortunately have never been in a situation where I've needed to jack up a car. Isn't there a first for everything? Another reason I asked is because after doing some research I have found that the jack that comes with the A8's are potentially not safe. see here A8 car jack is unfit and unsafe. - AudiWorld Forums . It may be that this is a d2 jack that failed. I have also heard that changing the parking brake motor is not a complex task plus I love challenges and learning new things.
    Hearing a direct opinion from A8 owners who have been there, done that regarding a specific issue is what this forum is all about.
    Please don't be concerned.
    1 1 0
  10. Re: How do you jack up an A8? I want to fix the parking brake.
    Sep 2009
    NW England
    Ok, we all have to start somewhere, and good to see that you're thinking about safety before you start.,
    Good luck
  1. Please Help A8 D3 Parking brake
    By mage in forum A8 - S8 - V8
    Last Post: 09-02-2018, 03:07 PM
  2. iphone fix for 2012 and data sim fix
    By a8 tech in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 03-09-2015, 03:05 PM
  3. ABS, Parking Brake, Squeeking brakes and brake lights!
    By medvwb6 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-10-2011, 05:35 PM
  4. Parking Brake
    By DouglasB6 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-10-2009, 05:05 PM
  5. Question Parking brake
    By ionic in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-06-2008, 08:29 AM
