Thread: Audi A8 no ignition no start
  1. Audi A8 no ignition no start
    Aug 2013
    2004 Audi A8 car has no ignition lights and will not start, I cannot find the ignition fuse all other fuses good under the hood, drivers side, passenger side fuses good, trunk fuses both sides good. Where is the ignition fuse located. Key will not come out of the ignition also. Door locks work.
    Battery is good 12.8 volts and have charger. Thank you
    Sent from my SCH-I605 using Tapatalk 2
  2. Re: Audi A8 no ignition no start
    Pembrokeshire
    22 Post(s)
    welcome to the forum.
    first thing that comes to mind is a flat battery ?
  3. Re: Audi A8 no ignition no start
    Aug 2013
    Thanks for your reply, battery voltage is good, its in my shop with a battery charger also voltage is a good 12.8v.
  4. Re: Audi A8 no ignition no start
    Aug 2013
    Do you know where the igntion fuse is located?
  5. Re: Audi A8 no ignition no start
    Sep 2011
    Lurking over a keyboard ...
    Have you had a fault scan on car? using say VCDS Link:- Ross-Tech: VAG-COM: Audi 200 / V8 / A8 / A8L Applications
    There will be a three letter engine code for your car can you provide it? that will allow me to check fuse list/wiring diagrams ...
    The data sticker will be either in spare wheel well or in service log book (which you may not have due to age of car?) ...
    An auto parts place or your Audi main dealer maybe able to tell you via your VIN ...
    And Welcome to VWAF!
  6. Re: Audi A8 no ignition no start
    Aug 2013
    Could it be the j518 box under the drivers front carpet area?
  1. Replies: 0
    Last Post: 25-01-2011, 12:03 PM
  2. ignition lights stay on car wont start
    By nickeym1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-01-2011, 12:12 PM
  3. Please Help Cluster judders on ignition start and clocks reset
    By Tony in forum Golf MK4 - 1999 - 2004
    Last Post: 18-07-2009, 12:34 PM
  4. Important Stammering Ignition Start AUDI A3 1.9
    By Nza in forum Audi A3 - Archive Topics
    Last Post: 21-01-2009, 01:36 AM
  5. door locks sounding on ignition start?
    By jonbaker in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-01-2008, 10:10 AM
