Thread: A4 2.5tdi AKE quattro start injection quantity adjustment
  1. A4 2.5tdi AKE quattro start injection quantity adjustment
    Aug 2013
    Finland
    My friend has a promlem with starting "half-warm" engine and timing should be correct so we thought what if we increase start injection quantity on group5 in the engine label. Only problem is that we dont have correct login code to access adaptation. What info would need to get
    right login code?
  2. Re: A4 2.5tdi AKE quattro start injection quantity adjustment
    Jun 2013
    Northern Norway
    26261 Works on mine.
    i`ve read that some have 26262
  3. Re: A4 2.5tdi AKE quattro start injection quantity adjustment
    Aug 2013
    Finland
    Thanks for those alternatives, have to try everything.
  4. Re: A4 2.5tdi AKE quattro start injection quantity adjustment
    Jun 2013
    Northern Norway
    No problem :-)
    By the way; is there any fault codes?
  5. Re: A4 2.5tdi AKE quattro start injection quantity adjustment
    Aug 2013
    Finland
    There is no fault codes.
  6. A4 2.5tdi AKE quattro start injection quantity adjustment
    Jun 2013
    Northern Norway
    Have you checked the timing in basic settings 004 ? Try looking at the blank pipe that goes to the ip from the filter. Look for air bubbles while starting.
  7. Re: A4 2.5tdi AKE quattro start injection quantity adjustment
    Jun 2013
    Northern Norway
    Does the coolant temp. Sensor give reasonable values?
  1. Cannot Start 2002 Audi Allroad 2.5TDI Automatic AKE after cam belts changed
    By ceilidhalfie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-07-2013, 06:07 PM
  2. Replies: 12
    Last Post: 11-04-2013, 10:55 PM
  3. Adjustment of injection quantity....
    By rob1976 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-04-2012, 12:05 PM
  4. 2001 audi allroad 2.5tdi -- AKE engine will not start.
    By hayabusa67 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-05-2011, 10:50 PM
  5. Wont Start A6 2.5 Quattro Avant (2000) AKE
    By PapaLarge in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-10-2009, 08:52 PM
