Thread: Alhambra timing belt
  1. Alhambra timing belt
    Jan 2010
    bridgwater uk
    With ref to my Alhambra 1.9 tdi 130 I have recently 2 months ago fitted a new timing belt and tensioner ,could someone explain to me what the purpose of the locking pin is as in the fitting instructions given with the timing belt kit from gates in gives instructions to remove locking pin on the tensioner and insert special tool or allen key and turn clockwise until tension pointer is between notches and then tighten nut , so what is point of the pin in the first place also I inspected to check belt today and the pointer had moved to outside the notches so I adjusted it could someone please advise me
  2. Re: Alhambra timing belt
    Aug 2011
    Meath
    IIRC the pin is to lock the tensioner away from the belt during fitting
  1. Replies: 4
    Last Post: 29-04-2014, 04:47 PM
  2. Question 2006 1.6 FSI SE - Timing Belt or Timing Chain?
    By wddonalds in forum Golf MK5 - 2004 - 2009
    Last Post: 04-02-2010, 05:44 PM
  3. Changing the timing belt and drive belt on Audi A6
    By Robbromilow in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-09-2009, 08:00 PM
  4. Cam belt timing belt tip , general
    By Conradvw in forum Archive posts
    Last Post: 11-01-2007, 04:29 PM
  5. timing belt/ cam belt change
    By jonoallen in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-11-2006, 01:24 PM
