Thread: Oil pressure on a 1.8t
  1. Oil pressure on a 1.8t
    Jul 2013
    Co.down Northern Ireland
    What should the oil pressure be in a 1.8t 190 bhp I've recently changed the turbo and just wants make sure I'm getting good pressure!! Checked it cold and was getting 62 psi and warm bout 38psi is that good or does the oil pump need changing??
  2. Re: Oil pressure on a 1.8t
    Aug 2011
    Meath
    Those figures look fine to me did you check the pressure at tickover?, did you pull the sump off and clear the sludge. You can run flushing oil through the engine but be careful it's extremely thin
  3. Re: Oil pressure on a 1.8t
    Jul 2013
    The reason I ask is because the car did a turbo! So have the car all back together and running again and thought it best to check the oil pressure to make sure it's as required!
    yes I've had the sump off and cleaned back as if it was brand new! flushed the engine! And put the bigger oil filter in replaced the oil feed pipe to the turbo! But wanted to be sure I was getting enough oil pressure! I just don't know what it should be! I'm guessing every car is different depending on mileage condition and servicing??
    the only think I can say is the car hs defiantly going better and a lot faster I can now feel the 190bhp
    thanks for your help
  1. Question Oil Pressure Warning Light - assumed oil pump fault. Advice and expected cost.?
    By dijjital in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-03-2017, 07:37 PM
  2. Oil Pressure Light on and oil temp not rising 02 AWX 1.9tdi
    By tone35 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-11-2012, 10:10 AM
  3. STOP oil pressure warning - oil pump failure! Help please
    By jamer78 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-01-2012, 03:54 PM
  4. Oil Pressure
    By lawser in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-05-2010, 06:37 AM
  5. Please Help Oil Pressure/Red Oil Light
    By misterme23 in forum Golf MK4 - 1999 - 2004
    Last Post: 01-06-2008, 10:07 PM
