Thread: P0299 Control Range Not Reached - Intermittent - MIL ON( Turbo fault)
  1. P0299 Control Range Not Reached - Intermittent - MIL ON( Turbo fault)
    Jul 2013
    Liverpool
    hi can any one confirm the following fault code from a reading taken from my Audi a3 2.0tdi ( CBA engine).I assume its sticky turbo vines /actuator. I have VAG rather VCDS now to read codes. Ive done the red hearing fixes N75, MASS air sensor & leaking vacuums. The fault always appears at 2250 revs in 6th gear doing 70mph + when I push down on the accelerator which over loads its and the glow plug light comes on. If left at the said speed for 10mintues engine management light comes on. Also anyone on Liverpool who can remove and clean the turbo unit? Thanks Robbie.
  2. Re: P0299 Control Range Not Reached - Intermittent - MIL ON( Turbo fault)
    Oct 2005
    16683/P0299/000665 - Ross-Tech Wiki
    Check the special notes section, in particular the latter half.
    There's a CBEA and a CBAB engine, but not a CBA.
  3. Re: P0299 Control Range Not Reached - Intermittent - MIL ON( Turbo fault)
    Jan 2012
    Coding Something
    Boost leak is my guess as its not reaching the requested boost level.
  1. Replies: 28
    Last Post: 20-09-2023, 01:39 PM
  2. P0299 - 006 - Control Range Not Reached - Intermittent B6 Passat
    By silversimpson in forum VCDS - Help Requests
    Last Post: 25-07-2019, 08:37 AM
  3. Replies: 12
    Last Post: 24-05-2017, 04:10 AM
  4. Replies: 8
    Last Post: 06-11-2014, 09:56 AM
  5. Please Help 000665 - Boost Pressure Regulation: Control Range Not Reached
    By SebRogers in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-08-2011, 11:01 AM
