Thread: Front brake pads....diy job?
Results 1 to 10 of 15
  1. Angry Front brake pads....diy job?
    Sep 2012
    Whitstable, Kent
    12 Post(s)
    Sooo, after having to get a local garage to change the rear pads because the flippin thing needed plugging into a computer to do it, the pad warning came on about 30 miles after leaving Morzine Been driving it for two weeks with it on so guess i'd better change them, but does it need plugging in to do the fronts too? Also how does the pistons go back in, push or screw?
    57 A6 2.0 tdi 140 SE. Standard except for MMI Basic + and a remap by Expert Tuning, and a want list as long as the equator!
  2. Re: Front brake pads....diy job?
    Nov 2012
    Australia, Melbourne
    Did mine recently, I pushed in the pistons with pliers and some home made wooden tool. Does not require VCDS. Pretty simple job. When the warning light goes on you can drive another 5000km approx. depending on your driving style.
    I also had brake fluid change soon afterwards in VW dealership because i noticed filthy stuff had contaminated the oil after i pushed the pistons in. Good luck if you embark.
  3. Re: Front brake pads....diy job?
    That is why I always recommend opening the bleed nipple when you press the piston back so it expels the old fluid and you can then bleed new fluid through. Regards Peter
    1 2 0
  4. Re: Front brake pads....diy job?
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by Andrew Turner View Post
    You could remove tyre to view if they need changing, sometimes the sensor develops a wiring fault and warning comes up ...
    There are a few versions of the front brake calliper, here is a link to how I did mine ... Link:- Front Brake Pads and Discs Change
    been driving it for two weeks with it on so guess i'd better change them
    Here's a handy table of info on wear limits & PR codes etc ... Link:- Pads need replacing - would anybody recommend Pagid?
    Quote Originally Posted by Cwizard View Post
    I also didn't loosen bleed nipple but never had any contamination ...
    I also had a brake fluid change though a few months later ...
  5. Re: Front brake pads....diy job?
    If you did not undo the bleed nipples and expel the fluid now do you know it was not contaminated. Regards Peter
    1 1 0
  6. Re: Front brake pads....diy job?
    Sep 2012
    Whitstable, Kent
    12 Post(s)
    Cool, thanks guys. Yeah am gonna take a wheel off and have a look, looking through the wheels i can see there's about 5mm left on the outside pads, and as the inside rears were almost to the mettal when the outside's had about 2 and a half mm left i assume sliding single piston calipers wear unevenly and there is less on the insides. I know how to change pads, done it regularly on our last 4 cars, just didn't know if it needed plugging in or not.
  7. Re: Front brake pads....diy job?
    Sep 2011
    Quote Originally Posted by Peter D View Post
    Ahh I see Peter ... I assumed contaminated oil would be visible in reservoir but then it depends how much of it is pushed back ...
    Anyhow I had a brake fluid change as there was no record in service log ...
    Will deffo do your recommend tip next time though mate ...
  8. Re: Front brake pads....diy job?
    Also remember that, depending on the caliper, OEM and somethird party pads are sided. The inside pad with the spring clip has a direction of rotation arrow on them. If you get it wrong they still fit but clunk every time you brake and drive you nuts. Regards Peter
    1 1 0
  9. Re: Front brake pads....diy job?
    Sep 2012
    Whitstable, Kent
    12 Post(s)
    Anyone know at what thickness the pad warning comes on? And do the rear pads have pad sensors too? I never got a warning for them, was only made aware of how warn they were when i had the rear tyres replaced.
  10. Re: Front brake pads....diy job?
    46 Post(s)
    rears dont have sensors, next service i will be needing pads and discs all round.
  1. How To Remove Towbar - DIY job?
    By patomlin76 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-11-2012, 05:02 PM
  2. Next Job, Replace Rear Brake Pads!!
    By ToMBoY_C in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-07-2011, 08:21 PM
  3. Please Help brake pads (front)
    By A6TYY in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2009, 12:28 AM
  4. Please Help A4 Front Brake Pads
    By abolt in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-10-2009, 10:52 PM
  5. A4 Front Brake Pads
    By mrp727 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-08-2007, 06:42 PM
