Thread: Door Control Module Help
Results 1 to 10 of 14
  1. Door Control Module Help
    Jul 2013
    Fife, Scotland
    Hiya, Yes im a NOOB, so sorry if this is a silly question, but, if you have a faulty Door Control Module, Would that effect the remote central locking? been trying to code my key as its never worked since owning my car (mk4 Golf GTTDi) so am wondering if this being faulty would cause this.
    Thanks.
    Last edited by Sam; 17-07-2013 at 09:58 AM. Reason: removing odd advertising links - possibly copied from another forum
  2. Re: Door Control Module Help
    Oct 2005
    Yes a faulty door control module would cause remote central locking issues.
    Do you have the results of a, or have you had a, diagnostic scan?
  3. Re: Door Control Module Help
    Jul 2013
    Fife, Scotland
    this was result :
    Address 19: CAN Gateway Labels: 6NO-909-901-19.lbl
    Part No: 6NO 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop#: WSC 00350
    VCID: F0E54E19B0B8B29
    1 Fault Found:
    01331 - Door Control Module; Driver Side (J386)
    49-10 - No Communications - Intermittent
    2003 VW Golf Gt TDi 130
  4. Re: Door Control Module Help
    Oct 2005
    Cleared and still returns?
    01331 - Ross-Tech Wiki
    Usual causes are broken wiring in the door jamb
    Check all fuses just to be sure.
    If you hold the key in the external door lock do the doors all lock and do the windows rise/fall?
  5. Re: Door Control Module Help
    Jul 2013
    Fife, Scotland
    yeah windows go down and up with key no problem, And yes code comes straight back, i thought i was doing something wrong when coding the key as it just doesnt code.
  6. Re: Door Control Module Help
    Oct 2005
    Have you had the door card off to visually inspect the unit? Does it have power and ground?
    If you can get to the wiring in the door jamb (inside the black concertina-type cover - remove the car side of the cover, it's easier to get that back on!) you should be able to identify any breaks.
    Can you operate all the other windows from the driver side controls?
  7. Re: Door Control Module Help
    Jul 2013
    Fife, Scotland
    Hi, just finished my work, inspected the wires all seems fine, ran a autoscan, which resulted in this:
    Wednesday,17,July,2013,17:10:57:32264
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Chassis Type: 1J - VW Golf/Bora IV
    Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
    76
    VIN: WVWZZZ1JZ4W065553 Mileage: 189110km/117507miles
    Address 01: Engine Labels: 038-906-019-ASZ.lbl
    Part No: 038 906 019 KJ
    Component: 1,9l R4 EDC 0000SG 5256
    Coding: 00002
    Shop #: WSC 01266
    VCID: 69D3A37D1362C31
    WVWZZZ1JZ4W065553 VWZ7Z0C8010804
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
    Part No: 1C0 907 379 M
    Component: ESP FRONT MK60 0102
    Coding: 0019970
    Shop #: WSC 01266 785 00200
    VCID: 346D020954204E9
    Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
    Part No: 3B1 907 044 C
    Component: CLIMATRONIC C 2.0.0
    Coding: 11000
    Shop #: WSC 01266
    VCID: 2143FB5DABD2CB1
    7 Faults Found:
    00538 - Reference Voltage
    06-10 - Signal too High - Intermittent
    00792 - A/C Pressure Switch (F129)
    35-00 - -
    00603 - Footwell/defroster Flap Positioning Motor (V85)
    37-00 - Faulty
    00797 - Sunlight Photo Sensor (G107)
    29-10 - Short to Ground - Intermittent
    01271 - Positioning Motor for Temperature Flap (V68)
    37-00 - Faulty
    01272 - Positioning Motor for Central Flap (V70)
    37-00 - Faulty
    01274 - Air Flow Flap Positioning Motor (V71)
    37-00 - Faulty
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 1C0 909 605 A
    Component: 27 AIRBAG VW51 01 0006
    Coding: 12855
    Shop #: WSC 01271
    VCID: 2241F451AED4D09
    1 Fault Found:
    00532 - Supply Voltage B+
    07-10 - Signal too Low - Intermittent
    Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
    Part No: 1J0 920 926 C
    Component: KOMBI+WEGFAHRSP VDO V20
    Coding: 05414
    Shop #: WSC 00000
    VCID: 2A511C71D6E4089
    4 Faults Found:
    01039 - Coolant Temperature Sensor (G2)
    30-10 - Open or Short to Plus - Intermittent
    00779 - Outside Air Temp Sensor (G17)
    00667 - Ambient Temperature Signal
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Coding: 00006
    Shop #: WSC 00350
    1 Fault Found:
    Address 46: Central Conv. Labels: 1C0-959-799.lbl
    Part No: 1C0 959 799 B
    Component: 1X Komfortgerát HLO 0003
    Coding: 00258
    Shop #: WSC 00350
    VCID: 36693801125C5C9
    Subsystem 1 - Part No: 1C2959802A
    Component: 1X Tõrsteuer.FS KLO 0202
    Subsystem 2 - Part No: 1C2959801A
    Component: 1X Tõrsteuer.BF KLO 0202
    Subsystem 3 - Part No: 1C0959811A
    Component: 1X Tõrsteuer.HL KLO 0202
    Subsystem 4 - Part No: 1C0959812A
    Component: 1X Tõrsteuer.HR KLO 0202
    3 Faults Found:
    01134 - Alarm Horn (H12)
    01135 - Interior Monitoring Sensors
    36-10 - Open Circuit - Intermittent
    01179 - Incorrect Key Programming
    35-00 - -
    Address 56: Radio Labels: 1J0-035-15x-56.lbl
    Part No: 1J0 035 152 E
    Component: Radio PHO 0002
    Coding: 00001
    Shop #: WSC 01317
    VCID: 2045FE59A0D8C29
    i then cleared all dtcs which came to this:Wednesday,17,July,2013,17:17:58:32264VCDS Version: Release 11.11.3
    76
    Coding: 00002
    Shop #: WSC 01266
    Readiness: 0 0 1 1 1
    Coding: 0019970
    Coding: 11000
    Shop #: WSC 01266
    Coding: 12855
    Shop #: WSC 01271
    Coding: 05414
    Shop #: WSC 00000
    Coding: 00006
    Shop #: WSC 00350
    Coding: 00258
    Shop #: WSC 00350
    Coding: 00001
    Shop #: WSC 01317
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Then tried to recode key, no joy
  8. Re: Door Control Module Help
    Oct 2005
    Probably a stupid question but how are you trying to recode the key?
    Have you bought a new key from somewhere?
  9. Re: Door Control Module Help
    Jul 2013
    Fife, Scotland
    its key i got with car, its only key i have, trying to code via vcds, but not happining? dunno if im doing something wrong
  10. Re: Door Control Module Help
    Oct 2005
    Any chance you could share the procedure you're trying?
  1. Question Partial electrics issue/ Poss Changing Drivers Door Control Module
    By nancol in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 10-02-2015, 12:33 PM
  2. Replies: 5
    Last Post: 15-10-2012, 10:20 PM
  3. Question steering control module for cruise control
    By doggydoctor in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 19-07-2012, 11:02 AM
  4. Replies: 0
    Last Post: 09-07-2009, 03:03 PM
  5. Please Help Door Control Module
    By Fido_Wokingham in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-05-2009, 02:59 PM
