Thread: Vibration noise HUD
  1. Vibration noise HUD
    Aug 2007
    Hook Hampshire
    21 Post(s)
    I have had the vibration noise coming from the HUD plastic window fixed on several occasions but the noise vibration still keeps coming back. Now at 43K miles and over 2 years old, has anyone had this problem fixed and what did the dealer do? Thanks.
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  2. Re: Vibration noise HUD
    46 Post(s)
    I had some rattles on my A6 dash just after I got it, Audi sorted it with pieces of felt under warranty.
  3. Re: Vibration noise HUD
    Oct 2012
    Spalding (Sometimes)
    I had this problem on mine.
    I actually did a temporary fix by shoving some thin card into the edges of the plastic screen until I could get it to the dealer to do a proper fix.
    I was expecting them to just put some felt where the card was but they insisted in replacing the entire HUD unit (which means taking the screen out) instead.
    The new unit looks to be a different design to the old one and so far (touch wood) the rattle hasn't returned.
  4. Re: Vibration noise HUD
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Thanks for that Mike. I can now ask them to fix it for good. It must be 3 times that they have tried putting felt around the housing, but to no avail. I will chase for a permanant fix. It just so happens that my windscreen has a 15mm crack on it so maybe some benefit on a new HUD display.
  5. Re: Vibration noise HUD
    Oct 2012
    Quote Originally Posted by shabazmo View Post
    They won't take out the screen if it has a crack in it as there is a risk it will fail. I had this problem with mine in that the day before it was due to go in, I picked up a significant stone chip.
    National Windscreens (who my insurer insisted I used) told me that they could fix the chip but that when the screen was taken out, it may not hold so recommended a replacement. In the case of the A7 there was no such thing as an OEM screen so they had to get it from the dealer anyway.
    So what ended up happening was that National Windscreens went to the dealer on the Monday morning and removed the old screen, the dealer then replaced the HUD then National Windscreens returned the following day to fit the new genuine Audi glass and then leave the dealer to recalibrate all the sensors etc.
    I think this is the first time I have had a screen replaced by the insurance recommended company and had no issues at all.
  6. Re: Vibration noise HUD
    Aug 2007
    Hook Hampshire
    21 Post(s)
    For some reason I thought that a new windscreen would be put in if the old one was removed. Silly me.
  1. P-zero vibration/ noise
    By Altifox in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 01-12-2012, 08:31 PM
  2. Please Help Problem with the DIS / HUD / LCD
    By Myk555 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-12-2012, 03:02 PM
  3. HUD and polarised sunglasses
    By Timothy Nathan in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 24-03-2012, 09:26 AM
  4. Strange Vibration Noise
    By kenny1001 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-10-2008, 08:21 AM
  5. Vibration Noise
    By stevepil in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-09-2008, 05:03 PM
