Thread: P261A - Fault Code
  1. P261A - Fault Code
    Thatcham, Berkshire
    Had an engine light on, fault code P261A.
    2008 CR 2.0 TDi
    2014 Audi Q3 S-Line Plus. 177Bhp 2.0 TDI S-Tronic Quattro
    2010 Lotus Evora 276Bhp
  2. Re: P261A - Fault Code
    Nov 2009
    46 Post(s)
    Are you experiencing any problems?
    And what was it scanned with?
    This is the only real thing I can find - http://www.dtcsearch.com/P261A/Generic/
    Get it scanned with VCDS or VW if possible.
  3. Re: P261A - Fault Code
    Thatcham, Berkshire
    Scanned with "Torque" on Android.
    Light now out (cleared).
    Will see if it reappears and then scan with VCDS (didn't have it to hand earlier).
    Other threads seem to indicate "Aux Water Pump" which is a 2nd waterpump to pump water round the engine after turning it off.
  4. Re: P261A - Fault Code
    Norfolk
    P261A = P2600
    P261B = P2601
    P261C = P2602
    P261D = P2603
    The pump is only required on hot engine shut down. Faults can be wiring or pump.
  5. Re: P261A - Fault Code
    Thatcham, Berkshire
    Output from VCDS scan....
    Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
    Part No SW: 03L 906 022 CL HW: 03L 907 309
    Component: R4 2,0L EDC G000AG 3107
    Revision: --H01--- Serial number: VWZCZ000000000
    Coding: 0000078
    1 Fault Found:
    009754 - Coolant Pump 2
    P261A - 000 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 97019 km
    Time Indication: 0
    Date: 2013.07.10
    Time: 09:27:53
    Freeze Frame:
    RPM: 2254 /min
    Speed: 113.0 km/h
    Voltage: 14.14 V
    Bin. Bits: 00000000
    Lambda: 95.5 %
    Temperature: 83.7°C
    Temperature: 85.5°C
    Readiness: 0 0 0 0 0
  6. Re: P261A - Fault Code
    Norfolk
    You probably need to replace the pump.
  1. Question 3TDI (BKN code) engine schematics and fault code listing
    By 20vcqdriver in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-02-2012, 02:41 PM
  2. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  3. VAGCOM Fault Code 00588 - Airbag fault
    By headache56 in forum VCDS - General Questions
    Last Post: 31-01-2009, 01:05 PM
  4. Question AIRBAG FAULT warning light and VAGCOM Fault Code 00588
    Last Post: 16-01-2009, 06:05 PM
  5. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
