Thread: VCDS in Burnham on Sea, Somerset - & First Scan
  1. VCDS in Burnham on Sea, Somerset - & First Scan
    Nov 2012
    Somerset UK
    Relieved that first scan didn't throw up anything major excepting a problem with my Xenons, which I was aware of since they don't auto-adjust as my Jag does (without sensors). However since it was MOT'd in May and passed (only C-links and brakes were advisory items since changed) I would suspect it's a fuse, sensor out of place/damaged or indeed a faulty headlight motor, since it's not been lowered.
    Address 55: Xenon Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 F
    Component: Dynamische LWR H02 0010
    Revision: 00000001 Serial number:
    Coding: 0000003
    Shop #: WSC 02325 758 00200
    VCID: 3D71D8A964F652F00BD
    2 Faults Found:
    01539 - Headlights Not Adjusted
    005 - No or Incorrect Basic Setting / Adaptation - MIL ON
    Freeze Frame:
    Fault Status: 11100101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 39
    Mileage: 147960 km
    Time Indication: 0
    Date: 2013.06.27
    Time: 14:53:52
    01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
    010 - Open or Short to Plus - MIL ON
    Freeze Frame:
    Fault Status: 11101010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 39
    Mileage: 147960 km
    Time Indication: 0
    Date: 2013.06.27
    Time: 14:53:52
    Have done some reading up on the fault and will rectify in my own time.
    But if anyone's in need of a scan in Somerset or North Somerset just drop me a message.
  2. Re: VCDS in Burnham on Sea, Somerset - & First Scan
    Jan 2018
    Somerset
    Hi Mark, I could do with resetting my oil change light (2009 TT) if that's something you can do? I've just registered on the forum so I can't message people until I've posted 15 times. If you're able to help please could you drop me a PM with your number and I'll get in touch? I'm in the Burnham area. Thanks in advance
  1. VCDS in Southend on Sea - Essex
    By Jens0n in forum VCDS - Help Requests
    Last Post: 03-04-2013, 11:19 AM
  2. vcds scan required cambridgeshire
    By jas828 in forum VCDS - Help Requests
    Last Post: 03-02-2013, 04:05 PM
  3. A3 VCDS scan info required please
    By Gizmo68 in forum VCDS - Help Requests
    Last Post: 30-09-2012, 04:21 PM
  4. VCDS Lite - Taunton Somerset
    By Tumble in forum VCDS - Users Locations
    Last Post: 26-04-2012, 10:41 PM
  5. vcds program shuts down on scan
    By allroadkev in forum VCDS - Help Requests
    Last Post: 24-11-2009, 05:44 AM
