Thread: Courtesy/reading lights
  1. Courtesy/reading lights
    Aug 2008
    Hertfordshire
    Suddenly these lights have stopped working. I assume its a fuse.... but where is the fuse for these dam lights. Can anyone tell me ?? - I can't find them listed in the manual.
  2. Re: Courtesy/reading lights
    There is a control unit up in the roof light unit J528. And a 26 way connector could possible be the problem or the control unit itself. This should show up using diagnostics so locate a fellow forum member with VCDS.
    If you post up your email address I send you a drawing. If you can PM me then send it that way. Regards Peter
  3. Re: Courtesy/reading lights
    Sep 2011
    Lurking over a keyboard ...
    Hi Scottishman2 ,
    Welcome to VWAF! ...
    Here is a link to the VWAF members VCDS map, search for a member here ... Link:- VWAF User Location Map - VCDS - Google Maps
    As you have a low post count you may not be able to private message (PM) a member but you can PM the mod team and they can contact a member for you ...
    The mod team are A6_Chris, Eshrules and Mycarsavw ...
    ATB
    G
  4. Re: Courtesy/reading lights
    Aug 2008
    Hertfordshire
    Just as closure on this, the VW dealer said they could fix this - at an estimated cost of £1000..... I bought a torch!!
  5. Re: Courtesy/reading lights
    Did you check out the roof light unit J528 and the connector. Regards Peter
  6. Re: Courtesy/reading lights
    Aug 2008
    Hertfordshire
    Dealer said they checked it.... I've traded the Phaeton now -- got a Tiguan sport... not so many gadgets to go wrong, but I do miss the big beast -- fabulous car.
  1. Rear reading reading lights not working
    By Daftbrush in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-07-2011, 07:27 AM
  2. Question courtesy lights not coming on
    By pinrob in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-05-2011, 09:51 PM
  3. Courtesy Lights
    By Bernarddelaney in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-03-2011, 11:36 PM
  4. Courtesy / reading light comes back on
    By Debsbp in forum Golf MK3 - 1993 - 1999
    Last Post: 08-02-2008, 04:39 PM
  5. Puddle Lights and courtesy lights not working
    By PerArdua in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-01-2008, 01:43 PM
