Thread: 2.0 tdi 140 oil capacity?
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: 2.0 tdi 140 oil capacity?
    #11
    Nov 2012
    Somerset UK
    With my car on just over 90k miles I added some Auto-rx to the crank case changed the filter and have run it for 2800 miles, so it's due it's rinse phase of 3k miles with new oil and filter, then will change oil and filter again before the extended service interval is due.
    Auto-Rx Plus Non-Toxic Sludge Remover and Cleaner for Engines and Transmissions
    Will reset via VCDS for long service interval but will change oil/filter every 12 months, whether 12 months or long service interval VAG oil spec is 504/507.
  2. Re: 2.0 tdi 140 oil capacity?
    #12
    Dec 2012
    newtownabbey
    What year is your a6? Mine is 2006 and nearly sure it takes 4.5L
  3. Re: 2.0 tdi 140 oil capacity?
    #13
    Nov 2012
    Somerset UK
    It says in my auto-signature and that mine's a 3.0
  4. Re: 2.0 tdi 140 oil capacity?
    #14
    May 2015
    Scotts Head. Australia
    My 3rd passat and use my own vag tool. I do approx 60,000kn/year or 5,000 per month. I replace oil, filter and sump plug at 7,500km. I normally drain 1/2 litre less than I put in at previous change. In the past I changed oil at 15,000 (once) then 10,000 (4-5 times). At 15,000 change I had added 3/4 litre twice, and at 10,000 i had added 1/2 - 1 litre each time. I conclude that the black soot on exhaust and rear bumper was a positive indicator that the engine was burning oil quicker as the oil worked and aged. Also small performance "jerks and hickups" seem to come with age of oil, and disappear with new oil. After opinions from chemists (BP in Australia) re oil and fuel, I now use BP Ultimate diesel exclusively (it has injector cleaner in Australia, unlike all other brands)and I achieve long distance economy as low as 4.5l/100km (4.8 using air con in summer), and mixed running average of 5.2l/km. I use Nulon (VW Spec 507.00) Oil, and use moly oil flush each change. I use Moly ms2 friction modifier (each 3rd change). I also us Moly PDF additive at 50km intervals, and will use the moly engine "shock" cleaner as engine ages. My first 2.0tdi had 225,000km and going great when i sold it, and I still pass it often....12 months later. My current 2007 2.0tdi had 51,000km when purchased and it now has 112,000km, and seems to be performing much the same as my previous vehicle, but I do wish it had leather trim!! Didnt mean to launch the "magna carta", but thought my detailed history may help. PS.....I initially put 3 1/2 litres of new oil and after filter cavity is filled I generally add another 300ml which fills it neatly.
  5. Re: 2.0 tdi 140 oil capacity?
    #15
    Feb 2019
    Kent, Maidstone
    Hello Mate
    Ive been working on them for last 5 years
    There is a very helpful Website for what you after.
    I use to get oil from them and all the info as well, not just for the engine but for gearbox and transfer boxes or coolant and etc...
    Morris Lubricants - What Oil Do I Need?
    Sorry Ill introduce myself as well while im here
    MY name is Alex and I’m a Vehicle ProTechnician from Kent.
    I currently got Audi Q3 2.0 TDI Sline, SkodaFabia VSR 1.9TDI and Toyota Supra MK4.
    Had over 12 VAG group cars in last 4 Years! Most of them TDI.
    In 2018 I’ve created a Youtube Channel that gotover 170 videos. That include loads and mainly VAG car Problem solutions.Pretty much everything we got on the road.
    Aim of my channel is to help everyone with anycar issues including buying them as well. Have a quick look at my channel andSubscribe if you think it that it might be helpful to you one day!
    Share if you can, as this service is free and myaim is to dedicate myself 100% in to this. Success for me will be opening mylittle workshop where I can give honest help and advice and also support thischannel to provide as many videos and help as I can!
    I will really appreciate any support like subscribe, like or share of my channel!
    I can provide help in 5 Different languages.
    MY Youtube Channel is AlexTheGrumpyOne
    Facebook profile is also AlexTheGrumpyOne!
    www.youtube.com/c/alexthegrumpyone
  1. Which oil = 2.0 tdi 140
    By ihs61 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-06-2012, 07:25 PM
  2. audi a4 2.7 tdi engine oil capacity
    By big jase in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 14-07-2011, 05:45 PM
  3. 1.9 tdi oil capacity
    By Worf in forum 80 - 90
    Last Post: 29-07-2009, 11:34 PM
  4. 140 Tdi using oil?
    By boofont in forum Golf MK5 - 2004 - 2009
    Last Post: 27-11-2008, 12:31 PM
  5. Oil change A3 2.0L TDI 140
    By Geraldy212 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 29-04-2007, 04:04 PM
