Thread: HELP: 2000 AKE allroad towed home AGAIN!! Advise required
Results 1 to 10 of 12
  1. HELP: 2000 AKE allroad towed home AGAIN!! Advise required
    Ayrshire, Scotland
    18 Post(s)
    Hi All,
    some help required please
    My old trusty audi allroad, year 2000, 2.5Tdi AKE just broke down on way home from work tonight, was acceletaring hard off a roundabout and just died in 3rd gear about 3000rpm, turns over but no start, towed home, coil light starts flashing on towing, once home VCDS plugged in and scanned get these 2 faults:
    2 Faults Found:
    01318 - Control Module for Injection Pump (J399)
    49-00 - No Communications
    01268 - Quantity Adjuster (N146)
    37-00 - Faulty
    Readiness: N/A
    faults cleared and no codes come back even after lots of cranking, is this normal codes not coming back? does the coil light only flash and store a code as the car was being towed?
    so anyway 1st impression it looks like the fuel injector pump, but do you all agree? if so whats the recomended options: a recon one, or new unit and from who?
    can i fit a 2nd hand one or does it need coding?
    Im off to check belts are stll intact 1st!!
    I appreciate any comments as its an old bus and, as everyone, I dont really want to throw huge money at it changing the wrong parts!! I dont like the idea the fault codes dont come back!!
    Regards
    Andy
    PS: I aslo I owe my dad a new van, just ripped the towbar off his old rusty LDV in the last 100 yards of towing!!! Oh boy!!
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  2. Re: HELP: 2000 AKE allroad towed home AGAIN!! Advise required
    Southern County Softy
    20 Post(s)
    I think diesel bob is the place for recon pump. Not cheap..
    I would crack an injector and see if you have fuel.
    bloody interweb phone.
    A4 2.5 tdi QS (mapped)
  3. Re: HELP: 2000 AKE allroad towed home AGAIN!! Advise required
    Ayrshire, Scotland
    18 Post(s)
    belts in tact,
    cracked injector and get fuel out on cranking,
    now code:
    37-00 - Faulty
    keeps returning
    whats the opinions?
    regards
    Andy
  4. Re: HELP: 2000 AKE allroad towed home AGAIN!! Advise required
    Aug 2011
    Meath
  5. Re: HELP: 2000 AKE allroad towed home AGAIN!! Advise required
    london/ UK
    Take the pump off and send it to dieselbob for a rebuild...
  6. Re: HELP: 2000 AKE allroad towed home AGAIN!! Advise required
    Sep 2008
    Highlands
    12 Post(s)
    Hi Andy
    i think the injector pump is still on my old donor , I can enquire about it if you establish you need one .
    Vin
  7. Re: HELP: 2000 AKE allroad towed home AGAIN!! Advise required
    Ayrshire, Scotland
    18 Post(s)
    Hi All, thanks for all the info, I thought that would be the conclusion
    Hi Vin, if you can check the part number of your old pump I would be interested in it as an option, any one know where the part number is?? I cant find it easily pump is still on the car can the part no be seen like this?
    regards
    Andy
  8. Re: HELP: 2000 AKE allroad towed home AGAIN!! Advise required
    Sep 2008
    Highlands
    12 Post(s)
    Quote Originally Posted by bagpipingandy View Post
    regards
    Andy
    I will check and see if the guy has stripped it if so I ill be able to tell you where the number is
    Vin
  9. Re: HELP: 2000 AKE allroad towed home AGAIN!! Advise required
    Jul 2011
    Norway
    Pump nr. 059130106D or E ? If so it's plug and play, needs no coding. The insulation on the wires to the quantity adj. and the advance solenoid have a nasty habit to crack and fall off in pieces and
    makes a short to ground sooner or later. Take the pump off and get a used unit from Ebay and check the insulation on theese wires very carefully.
  10. Re: HELP: 2000 AKE allroad towed home AGAIN!! Advise required
    Ayrshire, Scotland
    18 Post(s)
    Update: The car tried to run with some easy start squirted in the intake, all timing checks out ok so Pump is now off, ready to send to diesel Bob, It is Part no 059 130 106 E which is plug and play on the older 2000 models as you say but there are no bargains out there just now so I will settle for a rebuild.
    Many thanks
    Andy
  1. Replies: 29
    Last Post: 14-06-2013, 12:02 AM
  2. Allroad 2.5tdi AKE Manual - What is the best remap?
    By skyegtb in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 31-03-2012, 04:58 PM
  3. 02 Allroad AKE missing and low power
    By acmo in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-03-2012, 08:12 PM
  4. Towed Home :-(
    By bammy67 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-08-2009, 08:28 PM
  5. Question Technical Advise Required
    By PDL in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-11-2008, 09:24 AM
