Thread: Loud crack, now rattle over uneven ground
  1. Loud crack, now rattle over uneven ground
    Sep 2007
    Hi all
    1999 Alhambra 110 AFN
    I was pulling out of junction onto a busy road, had to accelerate hard changed into second gear and heard a loud crack from the front, sounded like something had broke. So I pulled into a layby checked the brakes and the steering, it all felt ok. Decided I would drive her home. I couldn't feel anything wrong the rest of the drive home, only a couple of miles. The steering, brakes etc, felt as usual. I got to the side streets where I live and turning left another loud crack, and now rattling every time I go over speed bumps or uneven ground.
    When I got home I had a look underneath to see if I could see anything hanging off. I noticed that the grease from the passenger side CV joint was all round the inside of my rim. I ordered a new CV joint and replaced it, but the old CV joint seems ok, but to be safe I replaced it anyway. While I had the car up on the axle stands I had a good look underneath to see if I could see what had broken, but I couldn't see anything, I pulled and banged and shook everything I could, but didn't see anything. I started the car and noticed the driverside drive shaft is vibrating quite badly. The car still drives as she did. The loud rattling, its almost a jingling, like loose brake pads but a lot louder, happens over speed bumps and uneven ground, and started after the "Crack". Are there any bolts that are prone to breaking or anything else for that matter. I havn't driven the car bar to the place to work at it, because the crack really sounded like something metal had snapped.
    Any advice would be greatly appreciated.
    Many thanks
    Chips
  2. Re: Loud crack, now rattle over uneven ground
    Southern County Softy
    20 Post(s)
    Check for a broken spring.
    bloody interweb phone.
    A4 2.5 tdi QS (mapped)
  3. Re: Loud crack, now rattle over uneven ground
    Jul 2007
    possible drop links...rattle on sudden impacts and sound horrendous....only a tenner from most auto stores...easy to fit too.
    Matt
  4. Re: Loud crack, now rattle over uneven ground
    Sep 2007
    Thanks for the replies
    Changed the droplinks, no difference. I had replaced all the suspension arms last year, so I know what the noises are like. I had a good look round the arms, all the bushes are ok. I used my breaker bar to get some leverage on them, also cheked exhaust, top mounts, springs, and all the bolts in the engine/gearbox mounts. It seems as though its the coming from the gearbox, so to rule out driveshafts I swapped out mine with my brothers who owns Alhambra also, this made no difference. I have no trouble selecting gears, so could it's the diff ? its the ony thing left.
    Cheers for the help
    Chips
  5. Re: Loud crack, now rattle over uneven ground
    Aug 2011
    Meath
    Are the CV joints ok? As it only happens over rough ground I wouldn't think it's the diff
  6. Re: Loud crack, now rattle over uneven ground
    Sep 2007
    Cheers for the reply
    Going be a couple of days before I get another chance to have a look, but I'll let you know how I get on.
    Chips
  7. Re: Loud crack, now rattle over uneven ground
    Gwent
    antiroll bar itself?
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  1. possible cylinder crack
    By petew130 in forum Alhambra
    Last Post: 19-05-2010, 09:32 PM
  2. Question loud rattle on shutdown DMF failure symptom?
    By rs250gpracer in forum Golf MK4 - 1999 - 2004
    Last Post: 03-05-2010, 04:26 PM
  3. What's the Crack
    By wstrain87 in forum New Member Introductions
    Last Post: 19-09-2008, 03:58 PM
  4. Steering wants to go it's own way on uneven ground!
    By Dudey Head in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 29-07-2008, 02:04 PM
  5. vw golf making loud noise when turning and also when travelling on uneven roads
    By madz in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 01-05-2007, 06:40 PM
