Thread: Allroad Air Suspension Problems
Page 25 of 26 FirstFirst ... 1523242526 LastLast
Results 241 to 250 of 259
  1. Re: Allroad Air Suspension Problems
    Dec 2016
    cockermouth uk
    Quote Originally Posted by bagpipingandy View Post
    No problem,
    if the error light flashes on start on start up and compressor runs it suggests the car is lower than dynamic, does it look low on any corner?
    you are right to park it tonight in jacking mode and see if it sinks in the morning, if no further sinking and description above is what is happening refurbish the compressor
    any questions please just ask
    best regards
    andy
    Morning Andy
    Ive checked the car and its level but looking boy racer low. Its not however on its bump stops. I could hear the compressor come on and then cut out. Absolutely no lift possible.
    So, do you recommend one of your compressor refurb kits or is it worth looking for a reconditioned better quality compressor?
    Richard
  2. Re: Allroad Air Suspension Problems
    Ayrshire, Scotland
    11 Post(s)
    Is the car lower than when you parked it last night? Did it drop?
    regards
    andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  3. Re: Allroad Air Suspension Problems
    Jan 2017
    Vantaa, Finland
    Very cold weather shows air leaks more clearly, Park at level 3 if it doesnít sink at level 3 but does sink at level 1 itís 100% airbag leaking
    soapy bubbles on the lower bend of the airbag and park at level 1 to see if bubbles keep forming
    best regards
    andy
    I't didn't sink in jacking mode last night. It was just few degrees below 0 celcius degrees. Front right sinks when car is driven and it tries to adjust itself. Then aas flashes yellow light. It's c6 allroad. Seems loke there's problem with moist in valve unit, but the air can get out somehow from the system. So maybe the pilot valve is leaking because pf moist. Where it is located? Somewhere in compressor unit?
    Br.
    Samuel
  4. Re: Allroad Air Suspension Problems
    Ayrshire, Scotland
    11 Post(s)
    Quote Originally Posted by Retrostyla View Post
    Br.
    Samuel
    hi Samuel, did you park it in dynamic setting and leave it overnight?
    try thus and report back, if it doesn’t sink in dynamic then there is no leak, it may be a sensor issue, it’s not common for the valve to cause the car to sink,
    report back with car left left parked in dynamic
    best regards
    andy
  5. Re: Allroad Air Suspension Problems
    Jan 2017
    Vantaa, Finland
    try thus and report back, if it doesnít sink in dynamic then there is no leak, it may be a sensor issue, itís not common for the valve to cause the car to sink,
    best regards
    andy
    It was dynamic and jacking mode.
  6. Re: Allroad Air Suspension Problems
    Ayrshire, Scotland
    11 Post(s)
    Ok and when you started it in the morning no error light flashing?
    if no light flashing then there is no leak, however if car sinks when you drive it’s either a bad level sensor signal or compressor too weak
    Any fault codes?
    best regards
    andy
  7. Re: Allroad Air Suspension Problems
    Jan 2017
    Vantaa, Finland
    if no light flashing then there is no leak, however if car sinks when you drive itís either a bad level sensor signal or compressor too weak
    Any fault codes?
    best regards
    andy
    It begins to flash after driving for a while. Never immediately. Error is 02645 valve unit mechanical failure. I've tried to log the sensor status's, but nothing unusual can be noticed.
  8. Re: Allroad Air Suspension Problems
    Ayrshire, Scotland
    11 Post(s)
    what are you scanning with?
    What is full error description?
    Any corrosion on the 10pin connector to the valve block?
    best regards
    andy
  9. Re: Allroad Air Suspension Problems
    Jan 2017
    Vantaa, Finland
    best regards
    andy
    Both obd eleven and vcds. I have to check the corrosion.
  10. Re: Allroad Air Suspension Problems
    Dec 2016
    cockermouth uk
    Hi Andy
    No, I dont think that it dropped, and looking at it this evening theres no change.
    regards
    Richard
  1. Allroad air suspension compressor
    By douglasiain in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-09-2011, 12:38 PM
  2. Allroad suspension air compressor part no
    By vinpetrol in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-06-2011, 09:51 PM
  3. Allroad, Any one fitted an Arnott air suspension??
    By bagpipingandy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 27-07-2009, 03:07 PM
  4. allroad air suspension problem.
    By Foley in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 08-05-2009, 09:01 PM
  5. What's the A6/Allroad Air Suspension Like?
    By ChillOut in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-04-2009, 09:53 PM
