Thread: Allroad Air Suspension Problems
Page 5 of 32 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 316
  1. Re: Allroad Air Suspension Problems
    #41
    Ayrshire, Scotland
    18 Post(s)
    Hi Jamie,
    what tool are you scanning with? was this fault code read in the suspension module or just an error code found on the cars scan?, a scan with VCDS will show up like this:
    XXXX EXAMPLE XXX
    Address 34: Level Control Labels: 4Z7-907-553.lbl
    Control Module Part Number: 4Z7 907 553 E
    Component and/or Version: - 2C1A1 D040
    Software Coding: 25500
    Work Shop Code: WSC 09999
    VCID: 479745C565B6D51
    1 Fault Found:
    01400 - Suspension Level Control
    11-00 - Control Limit Not Reached
    XXX EXAMPLE XXX
    this tells us exactly what the error is and where, if you google your code: Supply error B+ sporadic-signal too low? it points to alternator Which is why i dont think this code is in the suspension module
    did you try to clear this code?
    if you can get a scan with VCDS it will help, I have heard some code readers will not scan suspension modules, use this forum to search for people near you with VCDS
    regards
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  2. Thumbs up Re: Allroad Air Suspension Problems
    #42
    Dec 2012
    Nottingham
    Quote Originally Posted by bagpipingandy View Post
    Hi Jamie,
    XXXX EXAMPLE XXX
    1 Fault Found:
    XXX EXAMPLE XXX
    regards
    Andy
    looks like I need to get the right code reader like you said, thanks for the help matey much appreciated.
    Has anyone who lives near nottingham just off J26 M1 got a VCDS code reader I can borrow?
  3. Re: Allroad Air Suspension Problems
    #43
    Jul 2013
    Prestwick, UK
    I have read the various helpful posts / threads about this and think a leak is present (somewhere) as well as weak compressor.
    In jack mode at P1 both front units deflate almost equally with the offside a little lower, however it took a dozen attempts to get pressure back in the front and some more on / off of the electrics to raise to P2 then P3. At present I am testing 'bagpipeandy' theory to see if I lose height overnight.
    Would it be more likely that I have a double failure or some sort of valve / pipe leading to valve limiting this to the font only approximate assumed pressure loss?
  4. Re: Allroad Air Suspension Problems
    #44
    Dec 2012
    Nottingham
  5. Re: Allroad Air Suspension Problems
    #45
    Ayrshire, Scotland
    18 Post(s)
    Quote Originally Posted by davidwills View Post
    I have read the various helpful posts / threads about this and think a leak is present (somewhere) as well as weak compressor.In jack mode at P1 both front units deflate almost equally with the offside a little lower, however it took a dozen attempts to get pressure back in the front and some more on / off of the electrics to raise to P2 then P3. At present I am testing 'bagpipeandy' theory to see if I lose height overnight.Would it be more likely that I have a double failure or some sort of valve / pipe leading to valve limiting this to the font only approximate assumed pressure loss?
    Hi David,If you have put it in jack mode overnight it should disable all signals from level sensors so any sinking should purely be air leaking somewhere the wheel airlines go individually to the valve block, if it sinks in jack mode when at all levels check these airline connections for leaks, if it doesn’t sink when left parked at level 3 but sinks at level 1 in jack mode this is definitely a leaking airbag or 2 if both corners sink! , spray the lower half of the rubber airbags with soapy water and look for bubbles if it still sinks in jack mode,also nip down to me in Maybole and pick up a repair kit for that compressor get you pumping up easily again!!RegardsAndy
  6. Re: Allroad Air Suspension Problems
    #46
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Quote Originally Posted by Allroad 2.7 T View Post
    You might give Crasher a try VW Audi Seat Skoda Specialists | Parts Service Modifications
    He's in Nottingham and posts prolifically on here:
    VW AUDI Forum - VWAF
    Cheers!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  7. Re: Allroad Air Suspension Problems
    #47
    Jul 2013
    Prestwick, UK
    Hi Andy,
    I came down this afternoon but you were not there.
    Have ordered online, can you recommend an 'expert' locally with whom I could leave the car for diagnosis and work perhaps?
  8. Re: Allroad Air Suspension Problems
    #48
    Ayrshire, Scotland
    18 Post(s)
    Hi Andy,I came down this afternoon but you were not there.Have ordered online, can you recommend an 'expert' locally with whom I could leave the car for diagnosis and work perhaps?
    Hi David,ah it was yourself, sorry I was not in, I'm just home from work I work at Spirit AeroSystems just along the road from you!! your kit is posted should arrive tomorrow,I can diagnose fault codes for you I have VCDS, I have no problems offering a scan and assistance to you, whats the issue or work you need require doing?? Affraid I don't use any local garages I tend to break and fix it myself, there are a few garages in Ayr who specialises in Audi's but never used any of them and I doubt allroad/air suspension experience though, regardsAndy
  9. Re: Allroad Air Suspension Problems
    #49
    Jul 2013
    Prestwick, UK
    Essentially, I was wondering if I could ask you to diagnose and repair the beastie. ? Paid absolutely of course.
    On the way past the broken tree the suspension went nose down today and stayed there with the green light (number one) flashing and the yellow warning light blinking away. It can be driven, this wasn't such a problem until I placed the car in jack mode for the first time and now the nose doesn't seem to want to come back up. I'm technically minded but not handed unfortunately.
    I intend to have the EGR blanked and Seditas re-map the car once done but wanted to get the suspension in better shape first.
  10. Re: Allroad Air Suspension Problems
    #50
    Ayrshire, Scotland
    18 Post(s)
    Hi David, I sent a PM to you, give me a ring to get you scanned & see what's up, if it sinks it is a leak, also sounds like compressor cant get it back up kit should sort that but we need the sinking looked at, if possible get car up to level 3 and leave it there (hopefully if it doesn't sink at level 3!!) regardsAndy
  1. Allroad air suspension compressor
    By douglasiain in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-09-2011, 12:38 PM
  2. Allroad suspension air compressor part no
    By vinpetrol in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-06-2011, 09:51 PM
  3. Allroad, Any one fitted an Arnott air suspension??
    By bagpipingandy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 27-07-2009, 03:07 PM
  4. allroad air suspension problem.
    By Foley in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 08-05-2009, 09:01 PM
  5. What's the A6/Allroad Air Suspension Like?
    By ChillOut in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-04-2009, 09:53 PM
