Thread: Allroad Air Suspension Problems
Page 4 of 32 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 316
  1. Re: Allroad Air Suspension Problems
    #31
    Ayrshire, Scotland
    18 Post(s)
    ok so fitting the new ring worked ok but the new ring wont wear out that quick unless either the cylinder was in bad condition or dirt gets into the air intake, or if the compressor relay is stuck on!! it could be lots of things causing poor performance also check the air output pipe and fitting for leaks and the pipe to the storage tank and its fitting, any leak will cause poor performance, I would recommend getting a fault code read to make sure the level sensors and ECU are all working ok too, your new compressor will work just fine but if there is a leak 6 months from now that compressor will show signs of poor performance too!! hence I recommend a quick check at everything just to preserve its lifespan and save you money, regards Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  2. Re: Allroad Air Suspension Problems
    #32
    Jan 2013
    Trondheim,Norway
    The new compressor comes with a new air intake, relay and temp sensor, so those things are covered. I will get the codes read, thanks for the tip!. The relay is not stuck as the compressor does not run that often. As said the car seems to level correctly otherwise, but it is slow. I`ve looked over the fittings/pipes and there does not seem to be any obvious faults there, But maybe I sholud spray the connctions with soap water to be sure.
    Sakke
  3. Re: Allroad Air Suspension Problems
    #33
    Ayrshire, Scotland
    18 Post(s)
    The new compressor does comes with an intake pipe but it is only a small section of the air in, you should check from the rubber connection which fits on to the "T" piece of the compressor to the air filter in the spare wheel well for blockage,
    a quick spray on the airline fittings & connections with soapy water will be a good enough check for leaks, i do think it is the compresor but best to check as a new compressor will work great but if there is an issue elsewhere it too will deteriorate in the same monnor
    regards
    Andy
  4. Re: Allroad Air Suspension Problems
    #34
    Dec 2012
    Nottingham
    Assistance needed pls.. Had the mechanical side of things checked out by a mechanic friend of mine and all good, He said there is no live feed to the compressor/pump. Does anyone know what could be the electrical problem and where the 40 amp fuse is situated, also a 506 fault code has flagged up, does anyone know what this code relates to?
    A bit of help would be greatly appreciated.
    Cheers,
    Jamie
  5. Re: Allroad Air Suspension Problems
    #35
    Ayrshire, Scotland
    18 Post(s)
    Is the suspension error light on all the time? you need a fault code read with VCDS sorry no idea what code 506 is?the 40 AMP fuse & relay for the compressor is under the steering wheel/above the pedals see this thread: Allroad 2.5 tdi ake suspension puzzling problem
  6. Re: Allroad Air Suspension Problems
    #36
    Dec 2012
    Nottingham
    Yes fella the warning light is stuck on and no live feed detected to the compressor. Will check the fuse now you have kindly advised of its location. Fingers crossed its a poor connection or blown fuse!
  7. Re: Allroad Air Suspension Problems
    #37
    Ayrshire, Scotland
    18 Post(s)
    No I don't think its the fuse, something else is stopping the compressor and putting the error light on, you need to get the fault codes read, it could be anything, we need to work out what the code 506 is, can you get a fault code read with VCDS (VAG COM), regardsAndy
  8. Re: Allroad Air Suspension Problems
    #38
    Dec 2012
    Nottingham
    Quote Originally Posted by bagpipingandy View Post
    Ill get my top Mechcanic mate on the code reader and firm up the fault code, can I then ask for a bit of help from you guys pls.
    cheers,
    Jamie
  9. Re: Allroad Air Suspension Problems
    #39
    Ayrshire, Scotland
    18 Post(s)
    ok, sounds good, you need to scan module 34, for suspension faults, regards Andy
  10. Re: Allroad Air Suspension Problems
    #40
    Dec 2012
    Nottingham
    The fuse is good and a error came up as follows.. Supply error B+ sporadic-signal too low?
    Cheers,
    Jamie
  1. Allroad air suspension compressor
    By douglasiain in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-09-2011, 12:38 PM
  2. Allroad suspension air compressor part no
    By vinpetrol in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-06-2011, 09:51 PM
  3. Allroad, Any one fitted an Arnott air suspension??
    By bagpipingandy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 27-07-2009, 03:07 PM
  4. allroad air suspension problem.
    By Foley in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 08-05-2009, 09:01 PM
  5. What's the A6/Allroad Air Suspension Like?
    By ChillOut in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-04-2009, 09:53 PM
