Thread: Allroad Air Suspension Problems
Page 26 of 32 FirstFirst ... 162425262728 ... LastLast
Results 251 to 260 of 316
  1. Re: Allroad Air Suspension Problems
    Ayrshire, Scotland
    18 Post(s)
    Hi richard
    but you say it’s boy racer low, is that lower than it’s lowest setting? Show us a photo of how the car sits, if the error light is flashing the car is lower than its lowest setting, when you start car does error light flash and compressor run for 120 seconds?
    best regards
    andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  2. Re: Allroad Air Suspension Problems
    Dec 2016
    cockermouth uk
    Quote Originally Posted by bagpipingandy View Post
    Hi richard
    best regards
    andy
    Hi andy
    Yes, lower than dynamic which is the lowest setting. And yes, the error light flashes after the compressor runs for 120 seconds. No green “lifting” light at all.,
    Bit dark at the mo but can get a pic tomorrow...
    Richard
  3. Re: Allroad Air Suspension Problems
    Ayrshire, Scotland
    18 Post(s)
    Quote Originally Posted by footfang View Post
    Hi andy
    Richard
    ok, when it is that low it will not keep sinking, it’s either a weak compressor or a big leak, refurbish compressor and check for any air escaping, I worked on my friend C6 recently where the hose from the compressor rubbed a hole in itself, check for this,
    best regards
    andy
  4. Re: Allroad Air Suspension Problems
    Dec 2016
    cockermouth uk
    best regards
    andy
    I have seen it lower - when i had a leak in a rear airbag a year or so ago; its nowhere near as low.
    Ill contact you for a refurb kit
  5. Re: Allroad Air Suspension Problems
    Ayrshire, Scotland
    18 Post(s)
    If both front and rear are low rear should be trying to lift, feel to see if it moves when error light flashes and compressor runs,
  6. Re: Allroad Air Suspension Problems
    Dec 2016
    cockermouth uk
    Hi Andy - Ive ordered a compressor kit from you and Ill let you know how we get on.. Cheers!
  7. Re: Allroad Air Suspension Problems
    Jan 2017
    Vantaa, Finland
    Andy, do you happen to know which values are in cm34, channel 003? First I assume is pressure reservoir pressure, but what is the other one? The second one drop immediately after the compressor shuts down.
  8. Re: Allroad Air Suspension Problems
    Ayrshire, Scotland
    18 Post(s)
    And a photo of what you mean, I cannot think off hand what the value is
    best regards
    andy
  9. Re: Allroad Air Suspension Problems
    Jan 2017
    Vantaa, Finland
    Heres view from obd eleven.
  10. Re: Allroad Air Suspension Problems
    Feb 2019
    Essex
    Hi All, I have recently bought my first allroad an 05 plate It has started to drop down to the bump Stop if left for 6hrs+
    Rear drivers side. I have left it overnight at all 4 different levels and always drops down, on start up compressor starts and it always levels it self up no problem. Looking through the service history the whole corner was replaced less than 6mts ago could a new bag develop a hole that quick? Any help would be much appreciated.
  1. Allroad air suspension compressor
    By douglasiain in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-09-2011, 12:38 PM
  2. Allroad suspension air compressor part no
    By vinpetrol in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-06-2011, 09:51 PM
  3. Allroad, Any one fitted an Arnott air suspension??
    By bagpipingandy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 27-07-2009, 03:07 PM
  4. allroad air suspension problem.
    By Foley in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 08-05-2009, 09:01 PM
  5. What's the A6/Allroad Air Suspension Like?
    By ChillOut in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-04-2009, 09:53 PM
