Thread: caddy maxi 1.9tdi 2009 bls engine
  1. caddy maxi 1.9tdi 2009 bls engine
    Mar 2013
    albania
    hello.my caddy has a lot of black smoke when i push the accelaration pedal.i have changed the charger pressure control but th same thing ehith the black smoke from the exchaust.
  2. Re: caddy maxi 1.9tdi 2009 bls engine
    43 Post(s)
    Have you had a fault code scan?
    When was the fuel + air filter changed?
  3. Re: caddy maxi 1.9tdi 2009 bls engine
    Mar 2013
    albania
    i have changed the oil and the filters.first it show the fault code p0299,turbo didnt work so i changed the charger pressure control and checked all the pipes and the hoses.now the car has power but a lot of black smoke when accelerating.
  1. BLS engine from Caddy/tourag fit into a passat
    By VwAdy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-05-2013, 11:15 AM
  2. Advice on buying a 2008 Caddy Maxi?
    By The Dude in forum The Commercial Range
    Last Post: 27-02-2010, 01:48 AM
  3. 2008 vw caddy maxi
    By Mini Mark in forum Chat - Anything with wheels
    Last Post: 29-05-2009, 01:38 PM
  4. Caddy Maxi Van - when will it have Touran front end ?
    By pollensa in forum The Commercial Range
    Last Post: 18-07-2008, 10:01 PM
  5. Volkswagen Unveils The New Caddy Maxi
    Last Post: 29-10-2007, 08:45 PM
