Thread: C6 Easter Eggs
Page 2 of 16 FirstFirst 123412 ... LastLast
Results 11 to 20 of 151
  1. Re: A6 Secrets, really? :)
    Aug 2012
    Oxford UK
    Quote Originally Posted by Brycie View Post
    I didn't mention it earlier as it wasn't me that found it, it was A6 Chris that told me I believe. The heating system remembers the temperature settings that were on for each key, so if I get in the car & put in my key, it'll return to the settings I last had it on, but if the Missus uses her key, it'll restore the settings that she last had it on with her key.
    My car doesn't appear to have this feature. Does it only apply in certain cases, or does it need to be enabled?
  2. Re: A6 Secrets, really? :)
    Jan 2011
    Stafford, UK
    It is only available with the memory seats option.
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
  3. Re: A6 Secrets, really? :)
    Jan 2013
    Lincs
    Quote Originally Posted by EssexGonzo View Post
    It took me 5.5 years to discover the residual heating function where after a run, with the engine off you can press and hold the climate on/off button for a couple of secs and the blower will start up and blow you hot air for as long as the engine block is warm.
    Saved me £££ when waiting for kids last winter.
    Also seems to blow out residual cool air as well - we use it for our dog.
    2006 A6 Avant 2.7 TDI quattro S-Line
    2015 Q5 2.0 TDI S-Line Plus
  4. Re: A6 Secrets, really? :)
    Jan 2013
    Lincs
    Quote Originally Posted by royclark View Post
    Another Audi anomaly - it works with my two keys, but I don't have memory seats....
  5. Re: A6 Secrets, really? :)
    Mar 2011
    Clitheroe, England
    11 Post(s)
    Ditto DieTryin', my seats are standard manual seats & this works for me.
    The Only Way Is A6!
  6. Re: A6 Secrets, really? :)
    May 2013
    Leicester
    I've had my A6 for just over 2 years now and love it when I discover something new. One of my favorites which I use all the time is the auto dropping passenger side wing-mirror. Select that mirror from the control on the drivers door, then when you put the car into reverse, the passenger side mirror dips down to show the curb. It returns to its normal position when you take it out of reverse. Ideal for reverse parking. The only downside, as I always leave that side mirror selected on the control-knob, I have to remember to recenter the control know when demisting the mirrors in the winter.
  7. Re: A6 Secrets, really? :)
    #17
    Nov 2012
    Somerset UK
    Mine memorises different heater settings on each set of keys and I don't have memory seats either, so another bit of learning for me!
  8. Re: A6 Secrets, really? :)
    #18
    46 Post(s)
    Quote Originally Posted by aoxomoxoa View Post
    You dont need memory for this. All cars have it as it runs off which key is used to unlock and turn the ignition on.
    I made this a while back -
  9. Re: A6 Secrets, really? :)
    #19
    Aug 2012
    Portsmouth
    Quote Originally Posted by fishus101 View Post
    I was led to believe this only works on certain cars (is it the face-lift model of the C6 A6)?
    It's a software 'hack'(?) that enables/disables it via VCDS... but apparently not available on my car
    The other tricks are great though, i'm still learning a few.
    Has everyone found the exterior lighting option for returning and leaving home? That's a nice touch.
    I've seen this option on the mirror control knob, but never figured out how to enable/disable/use it correctly... i don't want it constantly trying to demist it do i? What's the process???
    I tell you, I've never needed to work so hard with a car before... I even had to Google how to turn off the air-con!
  10. Re: A6 Secrets, really? :)
    #20
    46 Post(s)
    You can enable it on prefacelift if you have a comination of folding/dimming mirrors, theres a big thread in this section if you search for mirror tilt.
    Mirror defrost will only work if the frost icon is on the dash (ie below 5 degrees outside iirc) so even though the switch may be in the central position, it wont be heating the mirrors until the outside temp is cold enough.
    0 3 0
  1. Easter Bunnies
    By mwvw in forum Chat - Adult Banter - Sponsored by Audi VW Specialist Centre
    Last Post: 13-04-2010, 01:24 PM
  2. I love Easter!
    By elvismiggell in forum Chat - Completely Off Topic
    Last Post: 08-04-2009, 03:31 AM
  3. Eggs !!!
    By san in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 12-04-2007, 02:32 PM
