Re: Engine emissions control system warning light –
28-05-2013,09:34 PM
I didn't get the DPF light either. I did get the "running on" when the engine stopped, though, and I think this is a key symptom of the problem. This is one of the things the dealer will check for after the initial phase of the repair in the "stall test" (if you have the same issue). If it continues, the second step will happen as per my PM.
I'd get the car booked in as soon as you can. Good luck!
MF.
Now: E 53 AMG 4MATIC / Q5 2.0TFSi Prestige
