I've got the car mentioned in the thread title. I ran the VCDS through and got the log as below. There is no Engine Management light on; car runs absolutely fine and I've managed about 225miles from half a tank (I am thinking it's good - but i'm sure it could be better)
Could someone help me in understanding the following log? i.e. what parts will I need to change etc? I've read on Ross-tech's website and it seems the MAF filter but if someone can confirm it for sure before I go ahead with the change, I would really appreciate it.
Cheers.
Control Module Part Number: 06A 906 033 EH
3 Faults Found:
16555 - Fuel Trim; Bank 1
P0171 - 006 - System Too Lean - Intermittent
Freeze Frame:
Lambda: 25.0 %
Lambda Factor: 1.008
Voltage: 0.440 V
Speed: 0.0 km/h
Lambda: 25.0 %
Lambda Factor: 1.000
Voltage: 0.440 V
Speed: 0.0 km/h
17511 - Oxygen (Lambda) Sensor Heating; B1 S1
P1103 - 006 - Performance too Low - Intermittent
Freeze Frame:
RPM: 608 /min
Mass Air / Rev.: 92.7 mg/str
Resistance: 0.00 kOhm
Hex Value: 0x0001
17658 - Fuel Level too Low
P1250 - 000 -
Freeze Frame:
Readiness: 0000 0000
