Thread: Phaeton LED Tail-Lights intermittent fault.
  1. Phaeton LED Tail-Lights intermittent fault.
    Apr 2013
    Hereford UK
    I am experiencing a spooky Phaeton Phenomenon with the LED taillights on my 2007 3.0 TDi.
    The yellow "failed bulb" warning light comes up on the dash + a "Please Check Lights" message as soon as the ignition is switched on, even if the headlight switch is in the fully off position.
    This sometimes doesn't happen at all, but if it does, it stays on until the ignition is switched off again.
    If the warning light on the dash is lit, then of the four tail-light clusters, only two are illuminated.
    The two that don't light up are the nearside inboard cluster (on bootlid) and offside outboard cluster (in rear wing).
    At least it means I always have a red tail light on both sides of the car!
    Would welcome any thoughts and ideas as to what's causing this, and how to cure.
  2. Re: Phaeton LED Tail-Lights intermittent fault.
    46 Post(s)
    Sounds like one of the boards has failed.
    A scan with vcds would show the fault.
    There could also be corrosion on the bulb holder hence the random warnings.
    Best bet is to remove them and have a look.
    Are your reverse and fog lights led or normal bulbs?
  3. Re: Phaeton LED Tail-Lights intermittent fault.
    Apr 2013
    Hereford UK
    Thanks A6 Chris - not sure if the other lights are LED or not, but thanks for your thoughts.
  4. Re: Phaeton LED Tail-Lights intermittent fault.
    Jun 2015
  5. Re: Phaeton LED Tail-Lights intermittent fault.
    Apr 2013
    Hereford UK
    Yes, the fault related to wiring failure inside the tube that carries all of the wiring into the bootlid. This braided conduit slides in & out of the bootlid as it opens and closes.
    Diagnosis and rectification was carried out by a reputable bodyshop that had previously done an insurance approved repair on a different area of my car.
    They charged me around £75 for the job, which I thought was great value!
  6. Re: Phaeton LED Tail-Lights intermittent fault.
    Jun 2015
  1. Led tail lights
    By mrmarc in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 13-05-2011, 07:58 PM
  2. LED tail lights
    By podwin in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-06-2009, 10:25 PM
  3. led tail lights
    By kiptaylor in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-06-2008, 07:41 AM
  4. A4 B7 Led Tail Lights?
    By poyorudo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-01-2008, 02:44 AM
  5. A6 LED tail lights
    By toff in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-11-2007, 09:05 PM
