Thread: Help I have Electrical Gremlins ESP issue
Results 1 to 10 of 19
  1. Help I have Electrical Gremlins ESP issue
    Leicestershire
    Anyone have the alternator wiring diagram for a 3.0tdi BMK and/or engine wiring diagrams please? or can someone come up with something that could be linked that is causing the intermittent load signal faults in the auto trans and abs modules?
    The problem is this:-
    I have an intermittent esp fault - drive for a few minutes - sometimes longer and the esp warning refer to manual pops up.
    The light goes out straight away and this will happen on every first journey. If I stop the car after about 5/10 mins of driving and restart the fault doesn't come back. If the car is left for longer i.e. a few hours/overnight - it happens again.
    On occasion the esp warning lamp stays lit - until the car is switched off again.
    Before this happens the esp button will turn off ASR at first press, and turn off ESP if held down for longer i.e. works as it should. After the fault appears the esp button will not turn ASR off, press the button and the esp light, lights up but then immediately goes out. Hold it for longer and it will turn off ESP illuminating the light on the dash.
    I believe even when the light goes out or the fault hasn't come up the ASR is not working as I chucked it round a bend in the wet and there was definite slipping but no ASR kicking in and no esp light flickering.
    So far I have changed the brake light switch. I didn't think it was this but for the cost it was worth a shot.
    This is the vcds reading:
    Code:
    Address 02: Auto Trans        Labels: 09L-927-760.lbl   Part No SW: 4F0 910 156 H    HW: 09L 927 156
       Component: AG6 09L 3.0lTDI RdW 0080
       Revision: --H01---    Serial number:        0040400
       Coding: 0000001
       Shop #: WSC 02335 785 00200
       VCID: 2855E6799BE83A9
    1 Fault Found:
    18265 - Load Signal
                P1857 - 000 - Error Message from ECU - Intermittent
                 Freeze Frame:
                        Fault Status: 00110000
                        Fault Priority: 0
                        Fault Frequency: 4
                        Reset counter: 40
                        Mileage: 160218 km
                        Time Indication: 0
                        Date: 2013.05.14
                        Time: 19:32:49
                 Freeze Frame:
                        RPM: 800 /min
                        RPM: 768 /min
                        RPM: 0 /min
                        (no units): 30.0
                        (no units): 23.0
                        Temperature: 32.0°C
                        T.B. Angle: 0.0°
    Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
       Part No SW: 4F0 910 517 E    HW: 4F0 614 517 A
       Component: ESP8 quattro    H03 0010
       Revision: 00000000    Serial number: 00000000000000
       Coding: 0004492
       VCID: 2649E84191FC2C9
    1 Fault Found:
    18265 - Load Signal
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 60
                        Mileage: 160218 km
                        Time Indication: 0
                        Date: 2013.05.14
                        Time: 19:32:48
                 Freeze Frame:
                        Hex Value: 0x0280
                        Hex Value: 0x40A2
                        Hex Value: 0x0000
                        Hex Value: 0x00AC
                        Hex Value: 0x00FF
    Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
       Part No SW: 4F0 910 043     HW: 4F2 820 043 B
       Component: KLIMABETAETIGUNGH11 0100
       Revision: 00000022    Serial number: 00000000036552
       Coding: 0001046
       VCID: DBBF09B51A3E211
    2 Faults Found:
    00256 - A/C Pressure/Temperature Sensor (G395)
                002 - Lower Limit Exceeded - Intermittent
                 Freeze Frame:
                        Fault Status: 00100010
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 59
                        Mileage: 160198 km
                        Time Indication: 0
                        Date: 2013.05.14
                        Time: 13:01:02
    01314 - Engine Control Module
                008 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 59
                        Mileage: 160219 km
                        Time Indication: 0
                        Date: 2013.05.14
                        Time: 19:35:33
    Address 46: Central Conv.        Labels: 4F0-910-289.lbl
       Part No SW: 4F0 910 289 E    HW: 4F0 907 289 E
       Component: Komfortgeraet   H14 0090
       Revision: 00900014    Serial number: 01000491320000
       Coding: 0008435
       Shop #: WSC 00137 211 56823
       VCID: 2C5D1A698F10169
       Part No: 1K0 951 605 A
       Component: LIN BACKUP HORN H01 1201
       Part No: 4F0 910 177
       Component: Innenraumueberw.H01 0010
    1 Fault Found:
    01134 - Alarm Horn (H12)
                012 - Electrical Fault in Circuit
                 Freeze Frame:
                        Fault Status: 01101100
                        Fault Priority: 3
                        Fault Frequency: 254
                        Reset counter: 20
                        Mileage: 158953 km
                        Time Indication: 0
                        Date: 2013.03.21
                        Time: 12:10:49
    I will be changing the a/c pressure sensor this weekend hopefully, I had at look at trying to do it with the bumper in place and it looks too fiddly so will do it with bumper off.
    The alarm fault also never clears even though the alarm works.
    from my reading and searching it appears to be alternator wiring harness or a grounding issue.... anyone got any other clues?
    this is what tells me it could be alternator wiring:
    ESP Light turns on after about 15min - TDIClub Forums
    How to: Fix broken Load Signal cable from Alternator - SEAT Cupra.net - SEAT Forum
    How I fixed fault code 17911 - TDIClub Forums
  2. Re: Help I have Electrical Gremlins ESP issue
    Sep 2011
    Lurking over a keyboard ...
    Concerning this ....
    00256 - A/C Pressure/Temperature Sensor (G395) 002 - Lower Limit Exceeded - Intermittent
    I know on another thread I said sensor could be at fault... but it could be something else as well ... Link:- Air Con not working...advice please
    Chadders had a regas 1st, then changed sensor, still has fault ... he has new compressor for sale ...
    In chronological order :-
    His regas thread Link:- Aircon issue problem or not??
    His fault scan Link:- Aircon problem found on scan
    His sensor change/compressor Link:- Air con ECON problem
    You may need to look at MVB's or get some proper diags done for AC ...
    2 1 0
  3. Re: Help I have Electrical Gremlins ESP issue
    Nov 2012
    Somerset UK
    Simple google of the fault
    Dreaded ESP Warning after 10 mins driving. Fault Code 18265
    All roads lead to Rome...kinda thang?
    2 1 0
  4. Re: Help I have Electrical Gremlins ESP issue
    Leicestershire
    Quote Originally Posted by MarkTM View Post
    Ah yes I did read this thread across my travels. Could well be the voltage regulator ...will need to test the output...
    Would you know how to test this?
    Audi A6 C6/4F 3.0 V6 TDI Quattro S-line - BMK
  5. Re: Help I have Electrical Gremlins ESP issue
    Leicestershire
    Quote Originally Posted by gupsterg View Post
    I'm hoping it's not compressor :-( just reading those posts now...
    Seeing as I already have the sensor I will try this then regas. If this does not fix it I will get the compressor checked out.
  6. Re: Help I have Electrical Gremlins ESP issue
    Nov 2012
    Somerset UK
    Tech
    No idea as never have tested mine in any car...but once again google is my friend
    How to Test Alternator Voltage Output (AutoUpkeep.com) - YouTube
    2 1 0
  7. Re: Help I have Electrical Gremlins ESP issue
    Sep 2011
    As you have VCDS you may find that running the MVB's in the battery regulation module will show you the occurrence of fault ...
    Link:- Audi Portal: ECU Diagnostic . Audi A6 4F (2005- ) . Energy Manager J644
    I've found using this screen capture software easier to see a fault occurrence i) then wading through the logs created in VCDS ii) for posting/sharing ...
    Link:- FastStone Screen Capture - The Best Screen Capture Software
    Here is an example of me having used it Link:- BMK 3.0 TDi hunting erratic idle revs ( Have I got the most lemon A6!!! ) - Page 27
    Also you can run an output test in module 61 which will excite alternator and show voltage output ...
  8. Re: Help I have Electrical Gremlins ESP issue
    Leicestershire
    Many thanks guys...
    I'll try all this out...
    Google doesn't seem to want to by my friend at the moment ....I've been reading through a lot of various alternator failure threads and symptoms are similar but not the same.
    So far I'm guessing that it is a fault somewhere in the alternator (most likely voltage regulator) and it's at the beginning stages of it's death as the car fires up fine, drives fine, all other electrics work fine.
    The ESP fault is only during the first drive after the car has been sat for a good few hours.
    Once driven for 10/15 mins then the fault does not occur again until the cycle is repeated.
    I will test and report back
  9. Re: Help I have Electrical Gremlins ESP issue
    Nov 2012
    Somerset UK
    My recommendation would go through the cheapest fixes methodically first, namely:
    1) Check battery with voltmeter and
    2) If out then check connections/clean contacts
    3) If 2 OK then purchase similar to this VW POLO T4 TOUREG BOSCH ALTERNATOR VOLTAGE REGULATOR 038903803E F00M145225 | eBay
    4) Investigate alternator repair if no point 3 available
    5) Move on to AC stuff...which will invariably be more expensive
    2 1 0
  10. Re: Help I have Electrical Gremlins ESP issue
    Leicestershire
    I've tested battery today with multimeter and it was12.38v.
    I then opened car inserted key and immediately turned radio/climate control off and it was just touching 12v then fired her up (with everything off) and it dropped to around 10.5v then climbed to a steady 13.85v.
    Turned lights,fans,radio on and it dropped to 13.73v then back up again to 13.85v.
    I'll do a vcds log and I'll also take it to one of those garages that can do a proper load test to confirm but would this indicate a dying/dead battery?
  1. electrical gremlins
    By Alaska in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-04-2013, 01:31 PM
  2. Please Help Electrical Gremlins!
    By acmo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-09-2011, 04:53 PM
  3. Electrical gremlins
    By mboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-04-2011, 08:40 AM
  4. Electrical Gremlins Strike
    By Martin Burnard in forum Golf MK5 - 2004 - 2009
    Last Post: 11-02-2009, 02:15 PM
  5. Electrical gremlins
    By brighton123 in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 09-04-2008, 11:06 PM
