Thread: Quiescent current stage 1 & 2 intermittent
Page 9 of 17 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 166
  1. Re: Quiescent current stage 1 & 2 intermittent
    #81
    May 2017
    Canterbury, Kent
    57 Post(s)
    BTW - am presently reading this VCDS Wiki in the error code:
    16618/P0234/000564 - Ross-Tech Wiki
    Does anyone know where the Boost Pressure Control Valve & Boost Pressure Sensor are located on the car? Does this now need to go into a proper garage for turbo pressure output diagnostic testing?
  2. Re: Quiescent current stage 1 & 2 intermittent
    #82
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    The map or boost sensor will be located on the inlet pipe before the inlet manifold. IIRC and your car is similar layout to my b5 passat, the n75 is on the front (timing belt ) end of the engine next to the spherical vacuum accumulator, if not just trace back the vac hose. I suspect you have sticking vnt mechanism in the turbo. You have vcds so you can measure requested vs. Actual boost while driving, look in measuring blocks, run a log and graph it or use vcds scope to trend the data. Try a vacuum pump on the vnt actuator to check for smooth movement, At least youve sorted the knackered egr and throttle flap!
  3. Re: Quiescent current stage 1 & 2 intermittent
    #83
    May 2017
    Canterbury, Kent
    57 Post(s)
    Quote Originally Posted by Rob69 View Post
    Thank you very much Rob - very much appreciated... I hope you're right!
    Excuse my ignorance, as I'm still a reasonable novice, but what's the "vnt mechanism" within the turbo? If it is this, is it a "strip and free up" type of job, or a "replace it asap" sort of job?
    Also - do you happen to know how I can measure the requested -v- actual boost within VCDS (i.e. the module and which options to pick)? I'm very happy to go out and do that right now, to see if the measurements pinpoint the root problem.
  4. Re: Quiescent current stage 1 & 2 intermittent
    #84
    Nov 2010
    104 Post(s)
    I dont have access to my car or vcds atm, so cant tell you step by step, but i did it last year on my 1.9 passat to check my turbo and map sensor, if you google a bit or look on vcds wiki you shoul find which measuring blocks and how to log or graph. Also google or youtube vnt, loads of vids showing you the gubbins.
  5. Re: Quiescent current stage 1 & 2 intermittent
    #85
    May 2017
    Canterbury, Kent
    57 Post(s)
    Right, ok... I'm learning!
    So your suspicion is that the veins / control ring inside the turbo are clogged/sticking? That would seem to make sense, as I'm sure I was watching the mechanic lever up what I now believe to be the actuator (underneath the bell housing where the small vacuum pipe was attached to the top), and he didn't like how stiff that assembly was. He reckoned it should have been much freer, and his plan (next Sunday - FML!) was to disassemble this to free it up. I think we're talking about the same thing n'est pas - in that the actuator that he didn't like the restricted movement of, is actually sticky or sticking because of (potentially) a build-up of crud inside the veins/control ring inside the turbo unit itself?
    Ifso, I think I understand this now... just got to work out how to use VCDS to get the turbo readings....
    I just watched this video to learn from - seemed like a knowledgeable guy doing the talking:
    How a VNT turbo works with diassembly and DIY repair of sticking vanes - YouTube
  6. Re: Quiescent current stage 1 & 2 intermittent
    #86
    Nov 2010
    104 Post(s)
    Yes, you're getting the picture. Let's know how you get on with it.
  7. Re: Quiescent current stage 1 & 2 intermittent
    #87
    Nov 2016
    england
    33 Post(s)
    Quote Originally Posted by rjsdavis View Post
    After reading your first messages since I last checked the thread (I'm no longer getting any notifications for some reason) I was thinking seems like turbo vanes (I had suspected this before but you had only mentioned underboost and although you do sometimes get underboost from what I've encountered and also what I've read overboost is more common, it may be worth mentioning any past changes in scans like that)
  8. Re: Quiescent current stage 1 & 2 intermittent
    #88
    May 2017
    Canterbury, Kent
    57 Post(s)
    Okey dokey - I've finished messing around trying to extract a log of data, and think I've been at least partially successful.
    Initially, I tried to bring up the measuring blocks as shown in this page: Boost check on VAGCOM (VCDS) - but VCDS wasn't really playing ball. When I entered 114 - in the top block, all of the fields just remained blank and empty. 115 worked, and brought up values etc, but I couldn't see anyway of bringing up/separating 115-3 and 115-4 - I could only bring up 115 as a three digit number and that was it. I left that and moved on.
    IIRC I went into the measuring blocks section of 01 - ENGINE, and again IIRC, simply used the "TURBO" button at the top of the page to bring up prescribed measuring blocks and values. Long story short, I've logged those into an Excel spreadsheet that I will attempt to upload into this thread, although I'm not sure how, as the buttons only seem to want to insert pics and videos.
    Anyway, whilst VCDS was logging the data, I took her from idle upto 3,500 RPM or so so that the values were showing the difference between requested and actual. I've just scrolled through the cells, and it's definitely showing a significantly "out of proportion" overboost, where at Specified, at about 3,000 RPM it was 1260-1280 mbars, but the actual was up at 1450-1500 mbars! I think I can see why the car is reporting an error with a clear "overboost condition".
    At the moment, the car is running, and if I'm gentle, along flatish, normal roads, keeping the revs under 3,000 before a gearchange, she'll run fine (once the Overboost fault code has been cleared) - indeed, I know exactly at what point on flatish roads the overboost fault will now trigger, and VCDS can clear it live and in realtime, and the car will immediately revert back to normal driving, once the fault has been cleared until you peak the revs/turbo pressure that's requested of the engine. Clearly, whilst she can "run about" on relatively normal roads, she cannot still be used.
    I tried the dual carriageway slip road (which is a fair old incline) and accelerated in third, gently - she wasn't having any of it at all and immediately went into limp mode at about 35 mph in 3rd at about 2100rpm. It's clear that more pressure is being required of the turbo to accelerate, even gently, up the incline to get up it, and accelerate up it. Therefore, it looks to me that as soon as there is sufficient difference between the specified and the actual - it's an automatic safety mechanism into limp mode, which I totally understand to protect the engine.
    So.... what to make of this? I don't know if this helps to firm up the suspected diagnosis of the control ring/nozzles being gunked up and sticking as a result?
    Oh, and by the way, I defo have a battery drain - discharge is sufficient to take the car from fully charged to "low battery warning" on the dash in just 48 hours. Have a charger trickle-charging the brand new battery permanently now, as I'm now pretty convinced that the drain killed the old new battery. Can't allow that to happen again, as I'll never get a second battery change under warranty!
    Ok, so it won't let me upload / insert an Excel file into the forum - I'm going to do an ugly copy and paste of the log data:
    Wednesday 24 January 2018 22:59:11:30461-VCID:75E15DB81CB7CBE9CA-8020 VCDS Version: Release 17.1.3 (x64) Data version: 20170320 DS267.7
    03G 906 016 MH R4 2.0L EDC G000SG 0948
    Group A: '003 Group B: '011
    Engine Speed Exhaust Gas Exhaust Gas Exhaust Gas Engine Speed Boost Pressure Boost Pressure Charge Pressure
    TIME (G28) Recirculat. (spec.) Recirculat. (actual) Recirc. Duty Cycle TIME (G28) (specified) (actual) Control Duty Cycle
    Marker STAMP /min mg/str mg/str % STAMP /min mbar mbar %
    0.13 882 295 490 99.6 0.29 882 1040.4 1009.8 78.1
    0.44 882 295 500 99.6 0.63 882 1040.4 1009.8 78.1
    0.79 882 295 490 99.6 0.94 882 1040.4 1009.8 78.1
    1.1 882 295 500 99.6 1.27 882 1040.4 1009.8 78.1
    1.43 882 295 500 99.6 1.58 882 1040.4 1009.8 78.1
    1.76 882 295 495 99.6 1.91 882 1040.4 1009.8 78.1
    2.07 882 295 495 99.6 2.23 882 1040.4 1009.8 78.1
    2.38 882 295 500 99.6 2.57 882 1040.4 1009.8 78.1
    2.73 882 295 490 99.6 2.88 882 1040.4 1009.8 78.1
    3.04 882 295 500 99.6 3.21 882 1040.4 1009.8 78.1
    3.37 882 295 495 99.6 3.52 882 1040.4 1009.8 78.1
    3.68 882 295 490 99.6 3.85 882 1040.4 1009.8 78.1
    4.01 882 295 490 99.6 4.16 882 1040.4 1009.8 78.1
    4.32 882 295 500 99.6 4.5 882 1040.4 1009.8 78.1
    4.66 882 295 485 99.6 4.82 882 1040.4 1009.8 78.1
    4.98 882 295 495 99.6 5.15 903 1081.2 1009.8 78.9
    5.31 1113 345 450 99.6 5.46 1113 1050.6 1009.8 70.2
    5.62 1008 295 525 99.2 5.8 966 1050.6 1030.2 76.9
    5.96 1134 330 470 99.6 6.12 1155 1060.8 1030.2 67.9
    6.27 1155 295 525 96.1 6.44 1155 1071 1040.4 67.1
    6.59 1218 315 525 95.3 6.76 1281 1101.6 1050.6 60.4
    6.91 1365 295 525 91.8 7.09 1365 1060.8 1071 60.4
    7.24 1365 295 540 87.5 7.4 1386 1050.6 1091.4 60.4
    7.56 1365 295 515 82.8 7.72 1407 1050.6 1101.6 60.4
    7.89 1428 295 445 77.7 8.04 1428 1050.6 1101.6 60.4
    8.2 1449 295 405 72.3 8.37 1470 1050.6 1091.4 60.4
    8.53 1491 295 360 67.6 8.68 1533 1050.6 1081.2 60.4
    8.84 1554 295 345 64.5 9 1554 1050.6 1071 60.4
    9.17 1575 295 320 62.9 9.32 1575 1050.6 1060.8 60.4
    9.48 1575 295 315 61.3 9.65 1596 1050.6 1050.6 60.4
    9.8 1596 295 300 60.5 9.95 1596 1050.6 1050.6 60.4
    10.11 1596 295 310 59 10.3 1575 1050.6 1040.4 60.4
    10.46 1575 295 300 58.2 10.62 1596 1060.8 1040.4 60.4
    10.77 1596 295 300 57.8 10.95 1617 1060.8 1040.4 60.4
    11.11 1596 295 290 57.8 11.28 1596 1050.6 1040.4 60.4
    11.44 1617 295 285 57.8 11.59 1617 1060.8 1040.4 60.4
    11.75 1596 295 300 55.5 11.91 1617 1060.8 1040.4 60.4
    12.09 1596 295 295 56.3 12.24 1596 1050.6 1040.4 60.4
    12.4 1617 295 290 57 12.56 1617 1050.6 1040.4 60.4
    12.72 1659 295 285 58.2 12.88 1680 1071 1040.4 60.4
    13.04 1659 295 290 58.2 13.19 1701 1081.2 1040.4 60.4
    13.37 1743 295 295 58.6 13.53 1722 1081.2 1040.4 60.4
    13.68 1743 295 285 58.6 13.84 1764 1101.6 1050.6 60.4
    14.01 1764 295 300 58.2 14.19 1764 1111.8 1050.6 60.4
    14.33 1764 295 305 57 14.5 1785 1101.6 1050.6 60.4
    14.66 1806 300 305 58.2 14.83 1785 1101.6 1050.6 60.4
    14.97 1806 305 300 59 15.13 1806 1111.8 1060.8 60.4
    15.3 1848 305 295 60.5 15.46 1890 1132.2 1060.8 60.4
    15.61 1848 305 305 58.6 15.77 1890 1132.2 1071 60.4
    15.95 1911 305 290 61.3 16.11 1890 1122 1071 60.4
    16.27 1932 310 305 60.5 16.46 1953 1132.2 1071 60.4
    16.61 1932 300 305 59.4 16.77 1974 1132.2 1081.2 60.4
    16.93 1953 300 310 59 17.1 1953 1122 1081.2 60.4
    17.26 1974 305 305 60.2 17.42 1953 1122 1081.2 60.4
    17.57 1974 305 310 60.2 17.74 1995 1132.2 1091.4 60.4
    17.9 1974 305 315 59.8 18.05 1995 1142.4 1091.4 60.4
    18.21 1995 305 300 60.5 18.38 1974 1142.4 1091.4 60.4
    18.54 2016 310 305 60.5 18.69 2016 1132.2 1091.4 60.4
    18.85 2016 305 320 58.6 19.02 2037 1152.6 1101.6 60.4
    19.18 2037 315 310 60.2 19.34 2016 1152.6 1101.6 60.4
    19.49 2058 315 310 60.9 19.66 2058 1162.8 1101.6 60.4
    19.82 2058 310 305 60.9 19.98 2037 1152.6 1101.6 60.4
    20.13 2058 325 310 62.1 20.31 2058 1162.8 1111.8 60.4
    20.48 2079 330 315 63.3 20.63 2058 1173 1111.8 60.4
    20.81 2058 335 310 64.1 20.96 2100 1224 1111.8 60.4
    21.12 2142 350 335 65.2 21.28 2142 1244.4 1132.2 60.4
    21.47 2121 350 340 65.6 21.63 2163 1244.4 1142.4 60.4
    21.79 2163 350 350 65.2 21.95 2163 1254.6 1152.6 60.4
    22.12 2205 355 345 66.4 22.28 2205 1275 1162.8 60.4
    22.43 2226 360 360 65.6 22.59 2247 1285.2 1173 60.4
    22.76 2310 370 355 65.2 22.92 2352 1285.2 1193.4 60
    23.07 2415 375 355 64.1 23.23 2499 1275 1213.8 56.8
    23.4 2625 400 360 64.8 23.56 2688 1275 1254.6 51.3
    23.71 2751 415 400 64.1 23.87 2793 1275 1295.4 47.7
    24.04 2814 415 420 64.1 24.2 2856 1264.8 1346.4 43.8
    24.35 2877 420 415 64.5 24.51 2898 1264.8 1387.2 40.6
    24.69 2919 420 420 64.1 24.85 2940 1264.8 1417.8 37.5
    25.01 2940 425 425 63.3 25.19 2961 1264.8 1438.2 35.1
    25.35 2961 425 420 63.3 25.51 2982 1264.8 1448.4 33.1
    25.67 2982 425 420 63.3 25.84 2982 1264.8 1458.6 32
    26 3003 425 425 62.5 26.15 3003 1264.8 1468.8 30.4
    26.3 3024 430 435 62.5 26.48 3024 1264.8 1479 29.6
    26.64 3024 430 440 64.1 26.81 3045 1264.8 1489.2 28.4
    26.97 3024 430 440 61.7 27.13 3024 1264.8 1499.4 27.6
    27.29 3024 430 425 61.7 27.44 3045 1275 1499.4 28
    27.63 3066 430 430 64.5 27.78 3066 1275 1499.4 27.6
    27.94 3066 430 455 63.7 28.12 3087 1285.2 1519.8 26
    28.28 3108 435 450 64.8 28.44 3150 1315.8 1540.2 25.3
    28.61 3171 510 500 69.9 28.77 3192 1326 1581 21.7
    28.93 3192 540 585 68.8 29.1 3192 1326 1662.6 14.2
    29.25 3213 560 560 69.9 29.43 3150 1285.2 1703.4 7.1
    29.59 2982 400 475 52.7 29.74 2730 1101.6 1621.8 54.1
    29.89 2457 330 340 27.7 30.07 2121 1040.4 1397.4 60.4
    30.22 1869 295 285 30.1 30.38 1638 1030.2 1244.4 60.4
    30.53 1407 295 295 28.5 30.71 1197 1030.2 1132.2 65.1
    30.86 966 295 350 19.5 31.02 924 1040.4 1081.2 78.5
    31.18 903 295 305 34.4 31.35 903 1040.4 1050.6 78.5
    31.5 882 295 305 34.8 31.66 882 1040.4 1030.2 78.9
    31.83 882 295 290 41 32 882 1040.4 1020 78.9
    32.16 882 295 290 41 32.32 861 1050.6 1009.8 78.9
    32.49 882 295 285 42.2 32.64 882 1050.6 1009.8 78.9
    32.8 861 295 285 44.1 32.96 882 1050.6 999.6 78.9
    33.13 882 295 285 44.5 33.29 882 1050.6 999.6 78.9
    33.44 882 295 280 46.1 33.6 861 1050.6 999.6 78.9
    33.77 882 295 295 46.1 33.93 882 1050.6 999.6 78.9
    34.08 882 295 290 47.3 34.24 882 1050.6 999.6 78.9
    34.41 882 295 290 46.1 34.57 882 1050.6 999.6 78.9
    34.73 882 295 285 47.3 34.92 882 1040.4 999.6 78.9
    35.08 882 295 290 47.3 35.24 882 1050.6 999.6 78.9
    35.39 882 295 285 49.6 35.56 882 1050.6 999.6 78.9
    35.72 882 295 295 48 35.88 882 1050.6 999.6 78.9
    36.04 882 295 275 51.6 36.21 882 1050.6 999.6 78.9
    36.37 882 295 275 53.1 36.53 882 1050.6 999.6 78.9
    36.68 882 295 295 49.6 36.85 882 1040.4 999.6 78.9
    37.01 882 295 290 48.4 37.16 882 1040.4 999.6 78.9
    37.32 882 295 290 48.4 37.51 882 1040.4 999.6 78.9
    37.67 882 295 290 50.4 37.82 882 1040.4 999.6 78.9
    37.98 882 295 300 49.2 38.15 882 1050.6 999.6 78.9
    38.31 882 295 300 48 38.46 882 1040.4 999.6 78.9
    38.62 882 295 290 50.4 38.79 882 1050.6 999.6 78.9
    38.95 882 295 285 50.8 39.1 882 1040.4 999.6 78.9
    39.26 882 295 305 48.4 39.43 882 1040.4 999.6 78.9
    39.59 882 295 295 48.4 39.74 882 1040.4 999.6 78.9
    39.9 882 295 290 48.8 40.08 882 1040.4 999.6 78.9
    40.24 882 295 285 50 40.4 882 1040.4 999.6 78.9
    40.56 882 295 280 50 40.73 882 1040.4 999.6 78.9
    40.89 882 295 285 50.4 41.04 882 1050.6 999.6 78.9
  9. Re: Quiescent current stage 1 & 2 intermittent
    #89
    Nov 2010
    104 Post(s)
    If you watch the turbo actuator rod as the engine is started you should see it travel to the limit stop to close the vanes and allow max boost when required, as engine load increases the n75 solenoid bleeds actuator vacuum to open the vanes and limit boost, you seem to have sticking mechanism, n75 solenoid fault or map sensor reading boost pressure incorrectly. If you had a faulty map sensor or n75 i would expect to see an error code for it or the offset between requested and actual to be there from the start rather than opening up as boost increases. I cant see your actual boost in the vcds log but am presuming requested and actual deviation increases as boost increases rather than the offset being there from the start. I'm no expert but do suspect the vnt is sticking. Sorry- got no idea where your current drain is going, vcds might indicate which module is remaing active or pulling fuses to certain items might show up on an ammeter in line with the battery, i've had the alarm siren internal battery fail, and do strange things to my alarm system, and they always seem to fail after several years.
  10. Re: Quiescent current stage 1 & 2 intermittent
    #90
    May 2017
    Canterbury, Kent
    57 Post(s)
    Hello Rob
    Thank you for that post - it all looks logical to me, and I'm unable to find anything that doesn't make sense to me.
    Can you not see the boost figures? There's a large table at the bottom of my last post, and they're all in there. Engine speed is the fourth column from the right, Specified Boost is the third from the right, Actual Boost is the second from the right. As you can see from the three columns, as the engine speed gets upto about 2800RPM, the specified and actual are largely in line with one another, but the actual then starts racing ever further away from the specified from about 2800-2900RPM onwards and just gets worse as the engine speed increases...
  1. The next stage
    By Borab0y in forum Golf MK5 - 2004 - 2009
    Last Post: 10-09-2010, 09:22 PM
  2. APR Stage 3
    By solaris10 in forum 2.0T, TSI and TFSI - Engine
    Last Post: 18-08-2010, 01:32 PM
  3. stage 3 cutch
    By bez101 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-11-2009, 10:16 PM
  4. Next stage complete
    By Borab0y in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-09-2009, 12:14 PM
  5. Anyone explain "stage 1" and "stage 2" torque settings?
    By jemthetaxi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-07-2008, 09:41 PM
