Thread: Wing mirrors turn down on reversing
Results 1 to 10 of 18
  1. Wing mirrors turn down on reversing
    Sep 2012
    A, A
    i know I read somewhere about being able to activate thishrough some highly complicated wizardry, can anyone point me in the direction of how I go about getting it done? I'm in Northampton and have an A6 2.0 2010 plate.
    Many thanks
    Kevin
  2. Re: Wing mirrors turn down on reversing
    46 Post(s)
    Find someone with VCDS - go into Module 52 (Passenger Door), Coding, Long Coding Helper and mirror tilt checkbox.
    Save and turn ignition off, select left hand mirror and select reverse.
    All facelift cars (yours!) can have it enabled whereas only certain prefacelift cars have the functionality.
    C6 Mirror Tilt on Reverse
  3. Re: Wing mirrors turn down on reversing
    Jan 2011
    Stafford, UK
    It didn't work on my 09 facelift, there is no list in long coding helper.
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
  4. Re: Wing mirrors turn down on reversing
    Sep 2011
    Lurking over a keyboard ...
    Are you able to post screen shot of what you have?
    I've been recently using this to capture screen videos ... Link:- FastStone Screen Capture - The Best Screen Capture Software
  5. Re: Wing mirrors turn down on reversing
    Jan 2011
    Stafford, UK
    I found this :-
    Enabling reverse mirror tilt on cars without memory seats: Go to module 52 Door Elect, Pass., Long Coding, Byte 4. If the byte has value 40 (cars without electrically folding mirrors), change it to 4C. If the byte has value 50 (cars with folding or folding/dimming mirrors), change it to 5C. Afterwards when reversing and the mirror knob is in passenger position the passenger side mirror will tilt while on reverse to better show the curb. Without memory seats it is currently not known if the tilt can be adjusted, it seems to default to a standard amount according to reports (see links below, thanks to EuroDan and Unisurfer). It was reported by -V- (here in Finnish: UltimateVW.COM) that 4C won't work in some cars, but value 44 instead does. This probably has to do with equipment levels. Ross-Tech has updated their VCDS/VAG-COM software data to include relevant bits with descriptions, so you can more easily try different combinations.
    HERE :- Interesting VAG-COM codes for Audi A5/A4 B8/Q5, many for A6/A8/Q7 as well (by LoCal) - Audi A6 Q7 A8 A4 A5 Retrofit Jälkiasennus Nachrüsten Retro-fit
  6. Re: Wing mirrors turn down on reversing
    Sep 2011
    Mine is a 2005 A6 (pre facelift) so no long coding, it had folding/dimming mirrors from factory, but a memory mirror housing on passenger side (I believe from factory as date codes on both housings/motors is same) ...
    • +0000128 = Outside Mirror Adjustment (Memory - PR-6XF/6XL)
    Above extract from Link:- Audi A6 (4F) Door Electronics Passenger - Ross-Tech Wiki
    I added above to module 52 coding and Mirror tilt on reverse worked ...
    i) it remembers per key mirror setting for tilt on reverse ...
    ii) can set tilt on reverse to any position I like ...
    iii) does remember mirror position before tilt on reverse and returns to that ...
    1 1 0
  7. Re: Wing mirrors turn down on reversing
    Jan 2011
    Stafford, UK
    but a memory mirror housing on passenger side.
    So the key is, you have to have a memory mirror fitted no matter if it is pre or facelift.
  8. Re: Wing mirrors turn down on reversing
    Jan 2011
    Stafford, UK
    I used to have wing mirrors on my Ford Anglia.
  9. Re: Wing mirrors turn down on reversing
    46 Post(s)
    Quote Originally Posted by royclark View Post
    Not this again!
  10. Re: Wing mirrors turn down on reversing
    Sep 2011
    From info that A6_Chris , MFGF , C4a5er say facelift only need coding...
    Quote Originally Posted by c4a5er View Post
    I can confirm that mirror dip on reverse will work once activated in 52 passenger door module. It doesn't dip enough to show the kerb/rear wheel, so of limited use but still worth having.
    Above from Link:- Mind if I join you? - Page 2
    But from what C4a5er is saying it has not setting/memory feature like I'm getting ....
    If like me you have non memory seats/mirrors you cannot set your own memorised position for mirror dip on reverse.
    Yes you can code the door module to dip the mirror but it's not much use because you can't set the actual amount of dip and there's no left/right movement.
    Above from Link:- A6 (C6) 2010 - Few VAGCOM questions?
    Before watching this video note these points ...
    i) two keys are used, to each I saved a different tilt preset , no limit on up/down and/or left/right
    ii) besides the keys having different keyring to denote key 1 or 2 note the AC temp per key as well
    iii) keys are removed when you are seeing the mirror return to position to highlight automation
    For further information on mirror tilt on reverse consult your owners manual ...
    1 1 0
  1. Question Heated Wing Mirrors / Door Mirrors / Side Mirrors / Side Mounted Rear Viewing Devices
    By simonrk57 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-05-2017, 07:53 PM
  2. wing mirrors
    By Bricktop20 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 11-11-2009, 07:31 PM
  3. Wing Mirrors
    By stusA3 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 01-05-2009, 06:57 PM
  4. Wing Mirrors
    By bez101 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-05-2008, 08:49 AM
  5. Wing Mirrors
    By bbb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-05-2007, 09:55 PM
