Thread: Sporadic Engine Fault Lights - but car still runs fine.
Results 1 to 8 of 8
  1. Sporadic Engine Fault Lights - but car still runs fine.
    Apr 2013
    Hereford UK
    My 2007 Phaeton 3.0 V6 diesel recently flashed up a warning in the central display "Engine Fault - Workshop". This was accompanied by an audible "pinging" warning sound. Main dealer cleared the fault code from the car's computer, which they said related to an intake manifold "runner" but the warning came back again a week or so later.
    Warning then moved on to a solid amber engine light in the rev counter, sometimes with a flashing amber glowplug light, and sometimes not. Main dealer read fault codes again, and says car needs a new flap motor and DPF sensor @ around 1,100.
    The warning lights have since extinguished themselves completely!
    I would welcome any thoughts and advice on what might cause this condition, whether any harm is likely to result if I just put up with the warning lights if they come back on, and is there a simpler cure than the major component replacement suggested by VW dealer. Mileage is around 52,000.
    The puzzling thing is the has car driven perfectly throughout, and fuel consumption is steady at around 33mpg.
  2. Re: Sporadic Engine Fault Lights - but car still runs fine.
    Southern County Softy
    17 Post(s)
    Manifold runner fault is common on the 3.0.
    The fault is normally the linkage.
    There is a repair kit available.
    Search on here for "intake manifold runner".
    Sent from my GT-I9305 using Tapatalk 2
    A4 2.5 tdi QS (mapped)
  3. Re: Sporadic Engine Fault Lights - but car still runs fine.
    Apr 2013
    Hereford UK
    Thanks for that. Although I'm unlikely to go the DIY route on this, it's really useful to build some understanding of how these things work to have an informed conversation with the garage I choose to deal with it.
  4. Re: Sporadic Engine Fault Lights - but car still runs fine.
    Dec 2011
    Cambridge
    I know you said you were unlikely to go the DIY route, but FYI it looks like the motor and manifold comes as one unit: VW Phaeton Inlet manifold.
    Also, have you done any long runs recently (for the other error message)? VW DPF Regeneration
  5. Re: Sporadic Engine Fault Lights - but car still runs fine.
    Apr 2013
    Hereford UK
    Thanks. Car is in daily use - 50 miles a day round trip minimum, mainly rural up to 60 mph, occasional Motorway and dual carriageway to 70 mph. DPF light (with the dotted pattern in the link) has NEVER lit up. VW dealer said from reading fault codes to replace the DPF sensor and one flap motor with manifold. I'm unconvinced that the car has any significant mechanical malfunction as it drives so well, but something is occasionally upsetting the cars's computer to flash up these warning lights. Started seven times today (in very warm weather) and covered 85 miles in total, with no engine warning light or glowplug light flashing at all. Does anyone else have any success from replacing the mechanical linkage alone as suggested by "kite" above?
  6. Re: Sporadic Engine Fault Lights - but car still runs fine.
    17 Post(s)
    Have a look in the audi A6 section for comments on the linkage kit.
    bloody interweb phone.
  7. Re: Sporadic Engine Fault Lights - but car still runs fine.
    Dec 2014
    Newcastle, UK
    Mine has similar problem. The fault light has come on twice in past 6 months. First time the engine went into "safe mode" and I limped home at 25-30mph unable to go any faster. Called AA and they tested and couldn't find any problems. Happened again last week. Turned engine off and on again and fault disappeared ... again. Car runs fine and no issues with acceleration, braking etc. I am concerned it may re-occur or whether I need to get it checked out again if it happens whilst in the vicinity of a VW dealership.
  8. Re: Sporadic Engine Fault Lights - but car still runs fine.
    Dec 2014
    Newcastle, UK
    Update: Still happening randomly. About 7/8 times in total now. Been back to VW dealership twice but they are saying that no faults have been logged? They've done an engine regen twice now too.
  1. Please Help Emissions Warning Light On, Fault code reads misfire...but she runs just fine!
    By michaelwoodward in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-02-2010, 03:09 PM
  2. Sporadic Hazzard lights !!! Help
    By welshdave in forum TT - 8N Forum - 1998 - 2006
    Last Post: 27-04-2009, 01:21 PM
  3. Replies: 1
    Last Post: 19-05-2008, 04:40 PM
  4. Golf Mk4 runs fine - but won't idle
    By soupdragon in forum Golf MK4 - 1999 - 2004
    Last Post: 15-01-2008, 07:14 PM
  5. Sporadic fault.
    By soldonseat in forum Leon
    Last Post: 15-04-2007, 01:04 PM
